O'Brien's Failed To Process - ODM v.2.1.0 (Regression - Fixed with 1da7077)
OS:
Solus v4.1 (Fortitude) - Budgie
Kernel 4.14.201-162.LTS
ODM:
v2.1.0 (SNAP)
Hostname webodm_node-odm_1
Port 3000
API Version 2.0.0
Engine odm
Engine Version 2.1.0
Queue Count 0
Max Images Limit None
Label node-odm-1
Last Refreshed 0 minutes ago (Nov. 5, 2020, 3:11 p.m.)
WebODM:
GIT clone & update
Dataset:
Processing Options:
Created on: 11/2/2020, 2:16:12 PM
Options: resize-to: -1, min-num-features: 120000, feature-quality: ultra, camera-lens: brown, max-concurrency: 2, depthmap-resolution: 1280, opensfm-depthmap-method: BRUTE_FORCE, use-hybrid-bundle-adjustment: true, mesh-octree-depth: 12, pc-classify: true, dsm: true, dem-resolution: 1, orthophoto-resolution: 1, verbose: true, debug: true, gps-accuracy: 5, pc-rectify: true
Processing Log:
[INFO]    Initializing ODM - Thu Nov 05 13:51:22  2020
[INFO]    ==============
[INFO]    build_overviews: False
[INFO]    camera_lens: brown
[INFO]    cameras: {}
[INFO]    crop: 3
[INFO]    debug: True
[INFO]    dem_decimation: 1
[INFO]    dem_euclidean_map: False
[INFO]    dem_gapfill_steps: 3
[INFO]    dem_resolution: 1.0
[INFO]    depthmap_resolution: 1280.0
[INFO]    dsm: True
[INFO]    dtm: False
[INFO]    end_with: odm_report
[INFO]    fast_orthophoto: False
[INFO]    feature_quality: ultra
[INFO]    feature_type: sift
[INFO]    force_gps: False
[INFO]    gcp: None
[INFO]    geo: None
[INFO]    gps_accuracy: 5.0
[INFO]    ignore_gsd: False
[INFO]    matcher_distance: 0
[INFO]    matcher_neighbors: 8
[INFO]    max_concurrency: 2
[INFO]    merge: all
[INFO]    mesh_octree_depth: 12
[INFO]    mesh_point_weight: 4
[INFO]    mesh_samples: 1.0
[INFO]    mesh_size: 200000
[INFO]    min_num_features: 120000
[INFO]    name: 84ae367c-4eb3-439c-a996-71358991ce09
[INFO]    opensfm_depthmap_method: BRUTE_FORCE
[INFO]    opensfm_depthmap_min_consistent_views: 3
[INFO]    opensfm_depthmap_min_patch_sd: 1
[INFO]    optimize_disk_space: False
[INFO]    orthophoto_compression: DEFLATE
[INFO]    orthophoto_cutline: False
[INFO]    orthophoto_no_tiled: False
[INFO]    orthophoto_png: False
[INFO]    orthophoto_resolution: 1.0
[INFO]    pc_classify: True
[INFO]    pc_csv: False
[INFO]    pc_ept: False
[INFO]    pc_filter: 2.5
[INFO]    pc_las: False
[INFO]    pc_rectify: True
[INFO]    pc_sample: 0
[INFO]    project_path: /var/www/data
[INFO]    radiometric_calibration: none
[INFO]    rerun: None
[INFO]    rerun_all: False
[INFO]    rerun_from: None
[INFO]    resize_to: -1
[INFO]    skip_3dmodel: False
[INFO]    sm_cluster: None
[INFO]    smrf_scalar: 1.25
[INFO]    smrf_slope: 0.15
[INFO]    smrf_threshold: 0.5
[INFO]    smrf_window: 18.0
[INFO]    split: 999999
[INFO]    split_multitracks: False
[INFO]    split_overlap: 150
[INFO]    texturing_data_term: gmi
[INFO]    texturing_keep_unseen_faces: False
[INFO]    texturing_nadir_weight: 16
[INFO]    texturing_outlier_removal_type: gauss_clamping
[INFO]    texturing_skip_global_seam_leveling: False
[INFO]    texturing_skip_hole_filling: False
[INFO]    texturing_skip_local_seam_leveling: False
[INFO]    texturing_skip_visibility_test: False
[INFO]    texturing_tone_mapping: none
[INFO]    tiles: False
[INFO]    time: False
[INFO]    use_3dmesh: False
[INFO]    use_exif: False
[INFO]    use_fixed_camera_params: False
[INFO]    use_hybrid_bundle_adjustment: True
[INFO]    use_opensfm_dense: False
[INFO]    verbose: True
[INFO]    Running dataset stage
[INFO]    Loading dataset from: /var/www/data/84ae367c-4eb3-439c-a996-71358991ce09/images
[DEBUG]   /var/www/data/84ae367c-4eb3-439c-a996-71358991ce09/images
[INFO]    Loading 87 images
[DEBUG]   Loaded GOPR0396.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23238729990584 | lon: -77.99098740001928 | alt: 261.24 | band: RGB (0)
[DEBUG]   Loaded GOPR0347.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2334273 | lon: -77.98604810000407 | alt: 260.13 | band: RGB (0)
[DEBUG]   Loaded GOPR0376.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2332344 | lon: -77.9885288 | alt: 261.05 | band: RGB (0)
[DEBUG]   Loaded GOPR0323.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234611900007394 | lon: -77.983562 | alt: 261.57 | band: RGB (0)
[DEBUG]   Loaded GOPR0350.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2347625 | lon: -77.98605430000416 | alt: 260.35 | band: RGB (0)
[DEBUG]   Loaded GOPR0346.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23296490004649 | lon: -77.98605689999133 | alt: 259.16 | band: RGB (0)
[DEBUG]   Loaded GOPR0379.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23230359996636 | lon: -77.98930459999336 | alt: 262.43 | band: RGB (0)
[DEBUG]   Loaded GOPR0383.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2340734000049 | lon: -77.98936610002464 | alt: 260.28 | band: RGB (0)
[DEBUG]   Loaded GOPR0377.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232748299956334 | lon: -77.98852969998492 | alt: 261.56 | band: RGB (0)
[DEBUG]   Loaded GOPR0344.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23218819999155 | lon: -77.98565329999578 | alt: 261.35 | band: RGB (0)
[DEBUG]   Loaded GOPR0341.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2333781 | lon: -77.98522360001868 | alt: 261.11 | band: RGB (0)
[DEBUG]   Loaded GOPR0380.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232715 | lon: -77.989372 | alt: 261.25 | band: RGB (0)
[DEBUG]   Loaded GOPR0333.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234199600000004 | lon: -77.98439260000556 | alt: 260.08 | band: RGB (0)
[DEBUG]   Loaded GOPR0392.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2336575 | lon: -77.99018810002232 | alt: 261.08 | band: RGB (0)
[DEBUG]   Loaded GOPR0352.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23570190001845 | lon: -77.9860881 | alt: 260.87 | band: RGB (0)
[DEBUG]   Loaded GOPR0365.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2336228 | lon: -77.987703 | alt: 261.08 | band: RGB (0)
[DEBUG]   Loaded GOPR0326.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.233160599932596 | lon: -77.9835668 | alt: 261.39 | band: RGB (0)
[DEBUG]   Loaded GOPR0351.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.235157899998754 | lon: -77.98605910001541 | alt: 260.06 | band: RGB (0)
[DEBUG]   Loaded GOPR0334.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234600300003656 | lon: -77.98439329998958 | alt: 260.2 | band: RGB (0)
[DEBUG]   Loaded GOPR0395.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23228839993256 | lon: -77.990375 | alt: 260.92 | band: RGB (0)
[DEBUG]   Loaded GOPR0353.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.235766699983344 | lon: -77.9866009 | alt: 261.87 | band: RGB (0)
[DEBUG]   Loaded GOPR0384.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23456289999229 | lon: -77.98936630002486 | alt: 259.63 | band: RGB (0)
[DEBUG]   Loaded GOPR0356.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23450780000415 | lon: -77.986879 | alt: 261.03 | band: RGB (0)
[DEBUG]   Loaded GOPR0378.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232275 | lon: -77.98863230001162 | alt: 261.59 | band: RGB (0)
[DEBUG]   Loaded GOPR0394.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23278070004546 | lon: -77.99018860002687 | alt: 260.64 | band: RGB (0)
[DEBUG]   Loaded GOPR0339.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2342445 | lon: -77.98522080000001 | alt: 261.21 | band: RGB (0)
[DEBUG]   Loaded GOPR0337.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23514890000327 | lon: -77.9852238 | alt: 260.77 | band: RGB (0)
[DEBUG]   Loaded GOPR0364.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23315329991646 | lon: -77.9877125 | alt: 260.56 | band: RGB (0)
[DEBUG]   Loaded GOPR0331.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23321959995121 | lon: -77.98440120000001 | alt: 259.27 | band: RGB (0)
[DEBUG]   Loaded GOPR0319.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2335985 | lon: -77.98273170000749 | alt: 258.38 | band: RGB (0)
[DEBUG]   Loaded GOPR0373.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2345848 | lon: -77.98853109997913 | alt: 261.53 | band: RGB (0)
[DEBUG]   Loaded GOPR0325.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.233670000000004 | lon: -77.9835645 | alt: 261.51 | band: RGB (0)
[DEBUG]   Loaded GOPR0318.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23308349997436 | lon: -77.98273989999912 | alt: 259.43 | band: RGB (0)
[DEBUG]   Loaded GOPR0401.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2345762 | lon: -77.99101349994982 | alt: 260.51 | band: RGB (0)
[DEBUG]   Loaded GOPR0336.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23539230000089 | lon: -77.98486379999122 | alt: 261.69 | band: RGB (0)
[DEBUG]   Loaded GOPR0366.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2341184 | lon: -77.98770969999126 | alt: 261.06 | band: RGB (0)
[DEBUG]   Loaded GOPR0327.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23271080014352 | lon: -77.9835655 | alt: 261.23 | band: RGB (0)
[DEBUG]   Loaded GOPR0357.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2341176 | lon: -77.9868791000017 | alt: 261.28 | band: RGB (0)
[DEBUG]   Loaded GOPR0361.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23223440004933 | lon: -77.98704450003088 | alt: 262.04 | band: RGB (0)
[DEBUG]   Loaded GOPR0340.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23387010000206 | lon: -77.98522169999005 | alt: 261.37 | band: RGB (0)
[DEBUG]   Loaded GOPR0391.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2341456 | lon: -77.99018509996421 | alt: 261.0 | band: RGB (0)
[DEBUG]   Loaded GOPR0386.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2354152 | lon: -77.989364 | alt: 260.25 | band: RGB (0)
[DEBUG]   Loaded GOPR0343.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23243060004271 | lon: -77.98522229999482 | alt: 261.15 | band: RGB (0)
[DEBUG]   Loaded GOPR0393.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23324779998355 | lon: -77.99018610000262 | alt: 260.96 | band: RGB (0)
[DEBUG]   Loaded GOPR0398.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23322089999911 | lon: -77.99101820005733 | alt: 259.15 | band: RGB (0)
[DEBUG]   Loaded GOPR0348.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.233789800000004 | lon: -77.9860436 | alt: 260.43 | band: RGB (0)
[DEBUG]   Loaded GOPR0367.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234508500000004 | lon: -77.98770740003319 | alt: 261.2 | band: RGB (0)
[DEBUG]   Loaded GOPR0345.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23245639993687 | lon: -77.9860556 | alt: 260.85 | band: RGB (0)
[DEBUG]   Loaded GOPR0320.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234071 | lon: -77.98273170000749 | alt: 259.47 | band: RGB (0)
[DEBUG]   Loaded GOPR0363.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23277080010633 | lon: -77.98772440003417 | alt: 260.51 | band: RGB (0)
[DEBUG]   Loaded GOPR0387.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.235759200000004 | lon: -77.9897352 | alt: 261.2 | band: RGB (0)
[DEBUG]   Loaded GOPR0335.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23507540000594 | lon: -77.98457290000124 | alt: 261.46 | band: RGB (0)
[DEBUG]   Loaded GOPR0381.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.233212800000004 | lon: -77.9893696 | alt: 260.62 | band: RGB (0)
[DEBUG]   Loaded GOPR0342.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23288510000177 | lon: -77.9852214 | alt: 260.97 | band: RGB (0)
[DEBUG]   Loaded GOPR0359.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.233104000000004 | lon: -77.98687970000402 | alt: 262.18 | band: RGB (0)
[DEBUG]   Loaded GOPR0358.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23362969999766 | lon: -77.98687890001452 | alt: 261.99 | band: RGB (0)
[DEBUG]   Loaded GOPR0316.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23297709998433 | lon: -77.98190350002079 | alt: 261.57 | band: RGB (0)
[DEBUG]   Loaded GOPR0388.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23547569998228 | lon: -77.99018870003148 | alt: 261.38 | band: RGB (0)
[DEBUG]   Loaded GOPR0354.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.235461099998695 | lon: -77.98687870001208 | alt: 261.27 | band: RGB (0)
[DEBUG]   Loaded GOPR0324.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2341524 | lon: -77.98357060000001 | alt: 261.65 | band: RGB (0)
[DEBUG]   Loaded GOPR0332.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2337113 | lon: -77.9844026000073 | alt: 259.78 | band: RGB (0)
[DEBUG]   Loaded GOPR0390.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234529 | lon: -77.99018410000977 | alt: 260.65 | band: RGB (0)
[DEBUG]   Loaded GOPR0360.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232750100040015 | lon: -77.9868786000088 | alt: 262.18 | band: RGB (0)
[DEBUG]   Loaded GOPR0385.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23503739999053 | lon: -77.98936139996148 | alt: 260.57 | band: RGB (0)
[DEBUG]   Loaded GOPR0330.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232825200021196 | lon: -77.98440530000886 | alt: 259.13 | band: RGB (0)
[DEBUG]   Loaded GOPR0375.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2335654 | lon: -77.98853009997873 | alt: 260.99 | band: RGB (0)
[DEBUG]   Loaded GOPR0399.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2337196 | lon: -77.9910256 | alt: 259.36 | band: RGB (0)
[DEBUG]   Loaded GOPR0382.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2336732 | lon: -77.98936050002145 | alt: 260.83 | band: RGB (0)
[DEBUG]   Loaded GOPR0371.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2354344 | lon: -77.98853170000966 | alt: 262.98 | band: RGB (0)
[DEBUG]   Loaded GOPR0374.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23410569999854 | lon: -77.98853009997873 | alt: 260.96 | band: RGB (0)
[DEBUG]   Loaded GOPR0368.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2349952 | lon: -77.98772030001507 | alt: 260.58 | band: RGB (0)
[DEBUG]   Loaded GOPR0362.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23231640001359 | lon: -77.98767989998781 | alt: 262.44 | band: RGB (0)
[DEBUG]   Loaded GOPR0328.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232324500000004 | lon: -77.98371530000237 | alt: 261.02 | band: RGB (0)
[DEBUG]   Loaded GOPR0338.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.234758400000004 | lon: -77.98522200000001 | alt: 260.81 | band: RGB (0)
[DEBUG]   Loaded GOPR0321.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2344616 | lon: -77.98273570000644 | alt: 259.63 | band: RGB (0)
[DEBUG]   Loaded GOPR0315.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23267510005718 | lon: -77.982158599973 | alt: 241.72 | band: RGB (0)
[DEBUG]   Loaded GOPR0397.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.232825899843505 | lon: -77.99102219999445 | alt: 259.68 | band: RGB (0)
[DEBUG]   Loaded GOPR0369.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23546809999244 | lon: -77.987718 | alt: 260.35 | band: RGB (0)
[DEBUG]   Loaded GOPR0355.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2349916 | lon: -77.98688489998844 | alt: 261.21 | band: RGB (0)
[DEBUG]   Loaded GOPR0372.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2349683 | lon: -77.9885375 | alt: 261.82 | band: RGB (0)
[DEBUG]   Loaded GOPR0389.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2350104 | lon: -77.99019269994632 | alt: 260.87 | band: RGB (0)
[DEBUG]   Loaded GOPR0317.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23291019998456 | lon: -77.98235540001944 | alt: 261.94 | band: RGB (0)
[DEBUG]   Loaded GOPR0349.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23428 | lon: -77.98605530000182 | alt: 260.01 | band: RGB (0)
[DEBUG]   Loaded GOPR0322.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2348465 | lon: -77.98309069999357 | alt: 261.17 | band: RGB (0)
[DEBUG]   Loaded GOPR0329.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.23236270001495 | lon: -77.9843925 | alt: 260.77 | band: RGB (0)
[DEBUG]   Loaded GOPR0400.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.2341112 | lon: -77.99102129995609 | alt: 259.75 | band: RGB (0)
[DEBUG]   Loaded GOPR0370.JPG | camera: GoPro HERO4 Black | dimensions: 4000 x 3000 | lat: 43.235763 | lon: -77.98814710000475 | alt: 262.96 | band: RGB (0)
[INFO]    Wrote images database: /var/www/data/84ae367c-4eb3-439c-a996-71358991ce09/images.json
[INFO]    Found 87 usable images
[INFO]    Parsing SRS header: WGS84 UTM 18N
[INFO]    Finished dataset stage
[INFO]    Running split stage
[INFO]    Normal dataset, will process all at once.
[INFO]    Finished split stage
[INFO]    Running merge stage
[INFO]    Normal dataset, nothing to merge.
[INFO]    Finished merge stage
[INFO]    Running opensfm stage
[INFO]    Forcing GPS DOP to 5.0 for all images
[INFO]    Writing exif overrides
[WARNING] Legacy option --resize-to (this might be removed in a future version). Use --feature-quality instead.
[INFO]    Altitude data detected, enabling it for GPS alignment
[INFO]    Enabling hybrid bundle adjustment
[INFO]    ['use_exif_size: no', 'flann_algorithm: KDTREE', 'feature_process_size: -1', 'feature_min_frames: 120000', 'processes: 2', 'matching_gps_neighbors: 8', 'matching_gps_distance: 0', 'depthmap_method: BRUTE_FORCE', 'depthmap_resolution: 1280.0', 'depthmap_min_patch_sd: 1', 'depthmap_min_consistent_views: 3', 'optimize_camera_parameters: yes', 'undistorted_image_format: tif', 'bundle_outlier_filtering_type: AUTO', 'align_orientation_prior: vertical', 'triangulation_type: ROBUST', 'bundle_common_position_constraints: no', 'camera_projection_type: BROWN', 'feature_type: SIFT', 'use_altitude_tag: yes', 'align_method: auto', 'bundle_interval: 100', 'bundle_new_points_ratio: 1.2', 'local_bundle_radius: 1']
[INFO]    running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata "/var/www/data/84ae367c-4eb3-439c-a996-71358991ce09/opensfm"
File "/code/SuperBuild/src/opensfm/bin/opensfm_main.py", line 8, in <module>
commands.command_runner(commands.opensfm_commands)
File "/code/SuperBuild/src/opensfm/opensfm/commands/command_runner.py", line 27, in command_runner
command.run(args)
File "/code/SuperBuild/src/opensfm/opensfm/commands/command.py", line 12, in run
self.run_impl(data, args)
File "/code/SuperBuild/src/opensfm/opensfm/commands/extract_metadata.py", line 10, in run_impl
extract_metadata.run_dataset(dataset)
File "/code/SuperBuild/src/opensfm/opensfm/actions/extract_metadata.py", line 36, in run_dataset
camera = exif.camera_from_exif_metadata(d, data)
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 583, in camera_from_exif_metadata
[calib['c_x'], calib['c_y']],
KeyError: 'c_x'
File "/code/run.py", line 69, in <module>
app.execute()
File "/code/stages/odm_app.py", line 86, in execute
File "/code/opendm/types.py", line 358, in run
File "/code/opendm/types.py", line 339, in run
File "/code/stages/run_opensfm.py", line 28, in process
octx.extract_metadata(self.rerun())
File "/code/opendm/osfm.py", line 260, in extract_metadata
self.run('extract_metadata')
File "/code/opendm/osfm.py", line 23, in run
File "/code/opendm/system.py", line 79, in run
Exception: Child returned 1
Notes:
  • Processed fine with similar settings under ODM v2.0.0 (SNAP).
  • The part that stands out to me in the above stacktrace is the KeyError: ‘c_x’ during lens calibration.
  • Same failure even on Default processing settings.
  • Failure is occuring with Old Orchard dataset as well
  • Failure does not seem to occur with other datasets (brighton, sand key, etc.)
  • Failure presents similarly to before Brown-Conrady camera model was merged
Regression indeed.
Will happen with any dataset processed with GoPros.
I’ve fixed it in Fix GoPro exif keyerror bug · OpenDroneMap/OpenSfM@1da7077 · GitHub
In a few hours it should be available from docker hub.
Thanks for the report!
Thanks for the fix! It was driving me nuts because I thought it sounded familiar.
Is this the type of fix that goes upstream to OpenSFM, or does it only really apply for ODM?
Should I delete this thread since you’ve already fixed the regression and this shouldn’t apply in the future?
Doesn’t go upstream, because we modified the camera model handling. Normally it would work fine in OpenSfM without the patch.
I wouldn’t remove the thread, it’s a good reference for the future.
