New user: Process exited with code 1
Mhm! Also, please don’t forget to include all the processing parameters that you change from default. It’ll be in the WebODM UI when you expand the Task under the Options menu. Same goes for the processing log.
See this post of mine for an idea of what that would look like:
Having all of that makes it way more reproducible for other people, as they know what the actual error message(s) are, and what exact settings you used.
That being said, if you’re using all defaults, you should get a proper stitch, and that’s not a bad place to start.
