Hello! I got this message and cannot process my images. I’ve tried methods in Question [There are no usable processing nodes - WebODM - OpenDroneMap Community] (There are no usable processing nodes) and Question How to solve “node-odm-1 seems to be offline” problem - WebODM - OpenDroneMap Community, but still can’t solve my problem.
Hostname webodm-node-odm-1
Port 3000
API Version None
Engine None
Engine Version None
Queue Count 0
Max Images Limit None
Label node-odm-1
Last Refreshed ago ()
Options (JSON)
I installed opendronemap the first time on Ubuntu20.04, and on the Vmware Station 15.5 Pro. My docker version is 20.10.20.
Through sudo docker run -p 3000:3000 opendronemap/nodeodm I can see the node-odm-1 has started.
Maybe it is the virtual environment makes my attempt failed?
