Cool datasets to show on new OpenDroneMap.org
Hi All,
Working on an updated OpenDroneMap website and I want to showcase datasets from you all there. I don’t really want to structure a contest or anything complicated. I’d like to build it as follows:
  • You submit a dataset you would be happy to see on the website
  • Screenshots welcome of point clouds, textured meshes
  • But: I’d also like either an export of the processed data or a link to the data hosted otherwise on the web in case it needs re-framed or otherwise modified to fit into the website
  • In submitting it, you agree to license it to OpenDroneMap under a Creative Commons CC-by 4.0
You’ll be credited on the website, your cool work shown off, and we’ll be able to highlight the cool stuff that OpenDroneMap can do!
To give a little flavor for what these might look like in context:
(with a small test to find the typos… oops)
And just to give a little clarity on process (as I had a good question on LinkedIn about how to submit):
To submit, reply here with a screenshot and link to your data (a cloud sharing link of your processed data works great). If the data are sensitive and you can only share a screenshot, then make it a great screenshot and we’ll try to work it in.
This is a great idea, I think I have allzip files if needed :-), without mentioning it, it's fine with me just as much, it's for participating.
Laurent
I can give you (and whomever else at ODM) a link to my QGIS files, but I’d rather not post a public link. Here are some screenshots from QGIS.
La Chorera 2023-04-27 detail.pdf (3.8 MB)
La Chorera 2025-04-09 detail.pdf (3.8 MB)
La Chorera 2025-04-09 vs 2023-04-27 detail.pdf (3.6 MB)
La Chorera 2025-04-09 vs 2023-04-27.pdf (2.9 MB)
What’s your name on LinkedIn?
These are fantastic! What great examples of elevation change mapping!
I will reach out to (Dutch) organisations who use WebODM.
Hope to give you some feedback soon.
Unfortunately I’m not allowed to share the source images / results.
Hopefully you can work with these images / screenshots.
Wiki: Afsluitdijk - Wikipedia
Subject: Monitoring new concrete protection blocks (“levvel blocs”)
Article: Eerste test duurzame Levvel-blocs positief - De Afsluitdijk
Date: 2023
Specs: GSD 1.0 + RTK + GCPs
Orthophoto
Ortho / DSM comparison
3D mesh
Wiki: -
Subject: Monitoring sand depot / volume calculation / change over time with slider functionality
Article: -
Date: april 2024 (left) vs juli 2024 (right)
Ortho
DSM
Oh, these are fantastic too. Will pass on to the web team. Thank you.
Edit: also — Dutch shore infrastructure is so mind-blowing in scale and design.
That will be fantastic. Thanks!
A first reply with a pretty specific use-case. In the Netherlands organisations need to have a permit for storing (large) depots of ground. In a permit a maximum height is defined, for example 10m above a specific reference point. This maximum height can be monitored with drone in combination with WebODM.
Organisation: OMWB (https://www.omwb.nl/)
Subject: Monitoring amount of sand above a specific (permitted) heigh.
Article:
Date: 2025
Specs: GSD 2.0 + RTK
That’s easily one of the cooler diagrams I’ve seen derived from drone data.
I can probably release the processing files to CC for one of the datasets here: Kandiyohi County Landfill - #3 by kclandfill
That would be fantastic. Thanks!
Did you have something you wanted to share @Laurent?
Some additional /related conversation here:
Can you talk a bit more about how the data are getting used in this context?
