Bruteforce matching, if you have plenty of time!
43 images of my bike shoes with my phone, thought I’d try Bruteforce matching, but wasn’t expecting it to take nearly a whole day vs 24 minutes!
It does extract a lot more features, but the time taken doesn’t justify it, as the resulting 3D models are similar.
43 images 21:51:29 Completed
|Options:|auto-boundary: true, dsm: true, feature-quality: ultra, matcher-neighbors: 10, matcher-type: bruteforce, mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 12000, orthophoto-resolution: 0.05, pc-classify: true, pc-filter: 0, pc-geometric: true, pc-quality: ultra, resize-to: -1, use-3dmesh: true|
|Area:|133.76 m²|
|Reconstructed Points:|15,057,444|
43 images 00:24:20 Completed
|Options:|auto-boundary: true, dsm: true, feature-quality: ultra, matcher-neighbors: 10, mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 12000, orthophoto-resolution: 0.05, pc-classify: true, pc-filter: 0, pc-geometric: true, pc-quality: ultra, resize-to: -1, use-3dmesh: true|
|Area:|149.8 m²|
|Reconstructed Points:|15,082,824|
Area is nonsense due to no GPS, so GSD set to default 5cm, when it was really more like <0.1mm
Matched 903 pairs (brown-brown: 903) in 77334.59451540001 seconds (85.64185439180511 seconds/pair).
2022-04-09 16:28:34,576 DEBUG: Good tracks: 169824
vs
Matched 903 pairs (brown-brown: 903) in 182.51813579999998 seconds (0.20212418172757474 seconds/pair).
2022-04-09 17:17:07,829 DEBUG: Good tracks: 61095
Bruteforce
Default
Nice models!
I am wondering how you are getting these images. I tried with the following (image) and it seems to build an entire world out there. While ignoring the object of interest.
Shiny surfaces are very difficult to reconstruct, especially with saturated areas of the image, plus the reflections, which change depending on where you are photographing from.
Is this also relevant to statues? I was planning to take some images in the neightbourhood and reconstruct them using OpenODM.
Shiny surfaces are a problem no matter where they are. Statues of non-reflective materials should reproduce fairly well with a sufficient number of images, so long as you can exclude most of any noisy backgrounds and sky, or else mask them out.
Using a boundary to restrict the area of reconstruction will help a lot too.
Ok. I’ll try with another subject.
A quick question - while taking the initial photos, should the entire subject be part of the photo or it’s okay if I take only parts of it in the image.
You don’t have to have any photos that show the whole subject, but you generally do need enough overlap and photos from multiple angles covering each point to get a good result. For non-uniform surfaces like statues that may include occluded areas, it can be a bit tricky, requiring more photos than you might expect.
You will probably have to adjust your parameters by trial and error a bit to get a good result, such as I did here -
