Following up from this thread: Misalignment between Bands in Mavic 3M multispectral images
I also have a M3M dataset that is showing this misalignment, perhaps not quite as bad as the original but it is still showing up.
The topic is now closed, so I am not sure if there was any update to this? Is everyone else with a M3M still seeing this issue?
We have not resolved this yet, no.
Thank you, is there anything needed in terms of datasets to help with this? Is the issue being tracked as I couldn’t find an open issue for it on GitHub?
If you’d like top contribute data and examples, you can use this Issue:
opened 09:14PM - 28 Aug 23 UTC
software fault
### How did you install WebODM (docker, installer, etc.)?
docker
### What'… s your browser and operating system? (Copy/paste the output of https://www.whatismybrowser.com/)
Chrome 116 on macOS (Monterey)
### What is the problem?
Cannot process dataset error. Dataset is composed from RBG images (jpg) and multispectral (4 extra files in tiff format), task output error:
[INFO] running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" compute_statistics --diagram_max_points 100000 "/var/www/data/30eecbf2-340e-4c2e-8a1a-696a52d9da38/opensfm"
2023-08-28 21:00:42,963 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x7f126c5ad2e0>
2023-08-28 21:00:42,963 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x7f126c5ad2e0> on colorbar
2023-08-28 21:00:42,963 DEBUG: Setting pcolormesh
2023-08-28 21:00:43,643 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x7f12705c1ac0>
2023-08-28 21:00:43,643 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x7f12705c1ac0> on colorbar
2023-08-28 21:00:43,643 DEBUG: Setting pcolormesh
/code/SuperBuild/install/bin/opensfm/opensfm/stats.py:1012: RuntimeWarning: invalid value encountered in divide
plt.imshow((camera_heatmap - lowest) / (highest - lowest) * 255)
[INFO] running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" export_geocoords --reconstruction --proj "+proj=utm +zone=50 +datum=WGS84 +units=m +no_defs +type=crs" --offset-x 683515.0 --offset-y 3752428.0 "/var/www/data/30eecbf2-340e-4c2e-8a1a-696a52d9da38/opensfm"
[INFO] Updating /var/www/data/30eecbf2-340e-4c2e-8a1a-696a52d9da38/opensfm/config.yaml
[INFO] undistorted_image_max_size: 2592
[WARNING] Unreliable UUID/capture time detected (no primary band match), will use filenames instead
File "/code/opendm/multispectral.py", line 239, in compute_band_maps
raise Exception("Unreliable UUID/capture time detected (no primary band match)")
Exception: Unreliable UUID/capture time detected (no primary band match)
File "/code/run.py", line 59, in <module>
retcode = app.execute()
File "/code/stages/odm_app.py", line 117, in execute
raise e
File "/code/stages/odm_app.py", line 81, in execute
File "/code/opendm/types.py", line 398, in run
File "/code/opendm/types.py", line 377, in run
File "/code/stages/run_opensfm.py", line 165, in process
s2p, p2s = multispectral.compute_band_maps(reconstruction.multi_camera, primary_band_name)
File "/code/opendm/multispectral.py", line 275, in compute_band_maps
s2p[p.filename] = filename_map[filename_without_band]
KeyError: 'DJI_20230215104308_0101_MS.TIF'
### How can we reproduce this? (What steps trigger the problem? What parameters are you using for processing? Include screenshots. If you are having issues processing a dataset, you must include a copy of your dataset uploaded on Dropbox, Google Drive or https://dronedb.app)
Parameters: dsm: true, radiometric-calibration: camera+sun
Dataset coming from DJI: https://terra-1-g.djicdn.com/851d20f7b9f64838a34cd02351370894/DJI%20Terra/%E5%A4%9A%E5%85%89%E8%B0%B1-Multispectral.zip
system
Closed
January 5, 2024, 9:19pm
5
