I booted up a clean install of Server 2019 and installed WebODM with the package windows installer. WebODM is only accessible over 127.0.0.1:29800. I am unable to access it over the local network with it’s IP of http://192.168.2.10:29800. Not really sure where to go from here.
Here are the logs as well from WebODM. Any advice would be appreciated.
"Booting WebODM 1.9.16 build 73..."
"Trying to connect to NodeODM localhost:29301..."
"nodeodm: info: Authentication using SimpleToken\r\n"
"nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n"
"nodeodm: info: No tasks dump found\r\n"
"nodeodm: info: Checking for orphaned directories to be removed...\r\n"
"nodeodm: info: Server has started on port 29301\r\n"
"Connected to NodeODM 2.2.0"
"redis-server: _._ \n _.-``__ ''-._ \n _.-`` `. `_. ''-._ Redis 3.2.100 (00000000/0) 64 bit\n .-`` .-```. ```\\/ _.,_ ''-._ \n ( ' , .-` | `, ) Running in standalone mode\n |`-._`-...-` __...-.``-._|'` _.-'| Port: 29379\n | `-._ `._ / _.-' | PID: 4180\n `-._ `-._ `-./ _.-' _.-' \n |`-._`-._ `-.__.-' _.-'_.-'| \n | `-._`-._ _.-'_.-' | http://redis.io \n `-._ `-._`-.__.-'_.-' _.-' \n |`-._`-._ `-.__.-' _.-'_.-'| \n | `-._`-._ _.-'_.-' | \n `-._ `-._`-.__.-'_.-' _.-' \n `-._ `-.__.-' _.-' \n `-._ _.-' \n `-.__.-' \n\n[4180] 25 Nov 11:40:38.638 # Server started, Redis version 3.2.100\n[4180] 25 Nov 11:40:38.638 * The server is now ready to accept connections on port 29379\n"
"Trying to connect to postgres localhost:29543..."
"C:\\WebODM\\resources\\app\\apps\\pgsql/bin/pg_ctl: server starting\r\n"
"C:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: psql: FATAL: password authentication failed for user \"postgres\"\r\n"
"C:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: exited with code 2"
"C:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: exited with code 0"
"Setting postgres password..."
"C:\\WebODM\\resources\\app\\apps\\pgsql/bin/psql: ALTER ROLE\r\n"
"Postgres password is set"
"python: Generated secret key\r\nOperations to perform:\r\n Apply all migrations: admin, app, auth, contenttypes, guardian, nodeodm, sessions\r\nRunning migrations:\r\n No migrations to apply.\r\n"
"python: exited with code 0"
"python: INFO:waitress:Serving on http://127.0.0.1:29800\r\n"
"python: [2022-11-25 11:40:59,545: INFO/MainProcess] Connected to redis://:**@127.0.0.1:29379//\r\n"
"python: [2022-11-25 11:40:59,551: INFO/MainProcess] mingle: searching for neighbors\r\n"
"python: [2022-11-25 11:41:00,562: INFO/MainProcess] mingle: all alone\r\n"
"python: [2022-11-25 11:41:00,578: INFO/MainProcess] pidbox: Connected to redis://:**@127.0.0.1:29379//.\r\n"
"python: [2022-11-25 11:41:00,579: INFO/MainProcess] celery@WIN-8V631D3C05J ready.\r\n"
"python: [2022-11-25 11:41:00,681: INFO/MainProcess] Received task: worker.tasks.cleanup_tmp_directory[4829a9e4-3b12-4197-9355-4fbe87c368e4] expires:[2022-11-25 20:10:57.866346+00:00]\r\n"
"python: [2022-11-25 11:41:00,685: ERROR/MainProcess] Task worker.tasks.cleanup_tmp_directory[4829a9e4-3b12-4197-9355-4fbe87c368e4] raised unexpected: FileNotFoundError(2, 'The system cannot find the path specified')\r\nTraceback (most recent call last):\r\n File \"C:\\WebODM\\resources\\app\\apps\\grass78\\Python39\\lib\\site-packages\\celery\\app\\trace.py\", line 385, in trace_task\r\n R = retval = fun(*args, **kwargs)\r\n File \"C:\\WebODM\\resources\\app\\apps\\grass78\\Python39\\lib\\site-packages\\celery\\app\\trace.py\", line 650, in __protected_call__\r\n return self.run(*args, **kwargs)\r\n File \"C:\\WebODM\\resources\\app\\apps\\WebODM\\worker\\tasks.py\", line 57, in cleanup_tmp_directory\r\n for f in os.listdir(tmpdir):\r\nFileNotFoundError: [WinError 3] The system cannot find the path specified: 'C:\\\\WebODM\\\\resources\\\\app\\\\data\\\\media\\\\tmp'\r\n"
"python: INFO Booting WebODM 1.9.16\r\nINFO:app.logger:Booting WebODM 1.9.16\r\n"
"python: INFO Created default group\r\nINFO:app.logger:Created default group\r\n"
"python: INFO Regenerate cache for app\\static\\app\\css\\theme.scss\r\nINFO:app.logger:Regenerate cache for app\\static\\app\\css\\theme.scss\r\n"
"python: INFO Created default theme\r\nINFO:app.logger:Created default theme\r\n"
"python: INFO Regenerate cache for app\\static\\app\\css\\theme.scss\r\nINFO:app.logger:Regenerate cache for app\\static\\app\\css\\theme.scss\r\nINFO Created settings\r\nINFO:app.logger:Created settings\r\n"
"python: INFO Running npm install for [coreplugins.changedetection.plugin]\r\nINFO:app.logger:Running npm install for [coreplugins.changedetection.plugin]\r\n"
"python: WARNING npm is not installed, will skip this plugin\r\nWARNING:app.logger:npm is not installed, will skip this plugin\r\n"
"python: INFO Running npm install for [coreplugins.cloudimport.plugin]\r\nINFO:app.logger:Running npm install for [coreplugins.cloudimport.plugin]\r\n"
"python: INFO Running npm install for [coreplugins.dronedb.plugin]\r\nINFO:app.logger:Running npm install for [coreplugins.dronedb.plugin]\r\n"
"python: INFO Running npm install for [coreplugins.elevationmap.plugin]\r\nINFO:app.logger:Running npm install for [coreplugins.elevationmap.plugin]\r\n"
"python: INFO Running npm install for [coreplugins.measure.plugin]\r\nINFO:app.logger:Running npm install for [coreplugins.measure.plugin]\r\n"
"python: INFO Added [[coreplugins.changedetection.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.changedetection.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.cloudimport.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.cloudimport.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.contours.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.contours.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.diagnostic.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.diagnostic.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.dronedb.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.dronedb.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.editshortlinks.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.editshortlinks.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.elevationmap.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.elevationmap.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.fullscreen.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.fullscreen.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.lightning.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.lightning.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.measure.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.measure.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.openaerialmap.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.openaerialmap.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.osm-quickedit.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.osm-quickedit.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.posm-gcpi.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.posm-gcpi.plugin]] plugin to database\r\n"
"python: INFO Added [[coreplugins.shortlinks.plugin]] plugin to database\r\nINFO:app.logger:Added [[coreplugins.shortlinks.plugin]] plugin to database\r\n"
"python: INFO Registered [coreplugins.contours.plugin]\r\nINFO:app.logger:Registered [coreplugins.contours.plugin]\r\nINFO Registered [coreplugins.diagnostic.plugin]\r\nINFO:app.logger:Registered [coreplugins.diagnostic.plugin]\r\n"
"python: INFO Registered [coreplugins.fullscreen.plugin]\r\nINFO:app.logger:Registered [coreplugins.fullscreen.plugin]\r\n"
"python: INFO Registered [coreplugins.lightning.plugin]\r\nINFO:app.logger:Registered [coreplugins.lightning.plugin]\r\nINFO Registered [coreplugins.measure.plugin]\r\nINFO:app.logger:Registered [coreplugins.measure.plugin]\r\n"
"python: INFO Registered [coreplugins.posm-gcpi.plugin]\r\nINFO:app.logger:Registered [coreplugins.posm-gcpi.plugin]\r\n"
"python: INFO Added admin to default group\r\nINFO:app.logger:Added admin to default group\r\n"
"python: WARNING:imagekit:The storage backend <django.core.files.storage.FileSystemStorage object at 0x000002538159F190> did not save the file with the requested name (\"CACHE\\images\\settings\\logo512\\af30a8ce19b9126af8cfbb7607eebf4c.png\") and instead used \"CACHE/images/settings/logo512/af30a8ce19b9126af8cfbb7607eebf4c.png\". This may be because a file already existed with the requested name. If so, you may have meant to call generate() instead of generate(force=True), or there may be a race condition in the file backend <imagekit.cachefiles.backends.Simple object at 0x000002538154C670>. The saved file will not be used.\r\n"
"python: WARNING:imagekit:The storage backend <django.core.files.storage.FileSystemStorage object at 0x000002538159F190> did not save the file with the requested name (\"CACHE\\images\\settings\\logo512\\53af5493584d5f7bc2141c753d869d4e.png\") and instead used \"CACHE/images/settings/logo512/53af5493584d5f7bc2141c753d869d4e.png\". This may be because a file already existed with the requested name. If so, you may have meant to call generate() instead of generate(force=True), or there may be a race condition in the file backend <imagekit.cachefiles.backends.Simple object at 0x000002538154C670>. The saved file will not be used.\r\n"
"redis-server: [4180] 25 Nov 11:45:39.023 * 10 changes in 300 seconds. Saving...\n"
"redis-server: [4180] 25 Nov 11:45:39.023 * Background saving started by pid 4424\n"
"redis-server: [4180] 25 Nov 11:45:39.123 # fork operation complete\n"
"redis-server: [4180] 25 Nov 11:45:39.123 * Background saving terminated with success\n"
