Hello! I purchased the WebODM Installer package which utilizes Docker on my Mac OS running Ventura 13.0.1. I am not very familiar with using Docker, and the installation appeared to run successfully, but it seems that processing node (node-odm-1) is offline and I can’t figure out how to get it online. The help section of the Install package I purchased directed me to this form. Is there some documentation on getting WebODM up and running on a Mac OS that I could refer to?
Is it the same issue as New Mac Install - Local Processing Node Offline - #4 by Saijin_Naib ?
Can you share the version of WebODM you are running? (Go to the “About” page).
Can you also show the details of the “node-odm-1” processing node (post a screenshot of the Processing Nodes → node-odm-1 page)?
Thank you, I just reviewed the Saijin_Naib post and tried the proposed solution; it worked for me. Much appreciated!
Glad it worked! Can you still tell us what version of WebODM you’re running? I thought I had pushed a fix for this, but perhaps it didn’t work. Knowing the version would help.
Version 1.9.17. I just downloaded it today.
