Web odm Installation on Mac Catalina 10.15.7
Is it possible to instal it, if yes then how to do that? Message coming:" could not copy docker application. please open finder, select the Docker volume on the left panel and drag &drop the Docker app to your Applications folder. Then start Docker manually and restart WebODM Manager". after that same problem coming again…
Thnx
hello,
I have webodm and docker on the same setup as you.
I don’t have any particular concerns.
Normally the app just installs.
Then we launch webodm and everything works.
what version of docker do you have ?
Laurent
Now i instal oder version and it works…but having problem with finishing 3d with 250 pics…pictures are lower quality, so, it shouldn’t be a problem…
