I want to share something with everybody.
This review focuses on application of UAS in landscape ecology and the questions linked to ecology. It does contain interesting information on Web ODM.
Villarreal, M.L., Bishop, T.B.B., Sankey, T.Ts., Smith, W.K., Burgess, M.A., Caughlin, T.T., Gillan, J.K., Havrilla, C.A., Huang, T., LeBeau, R.L., Norton, C.L., Sankey, J.B., Scholl, V.M., von Nonn, J., Yao, E.H., 2025. Applications of unoccupied aerial systems (UAS) in landscape ecology: a review of recent research, challenges and emerging opportunities. Landsc Ecol 40, 43. Applications of unoccupied aerial systems (UAS) in landscape ecology: a review of recent research, challenges and emerging opportunities | Landscape Ecology
I will not cite, since the details are in the publication:
- not all studies do use photogrammetry, some focus on questions that can be answered with different methods
- research lacks implementation and use of open-source software
- Web ODM is only used for 2 studies of the 161 examined ones
- there is a lack of reproducible processing code (basis of scientific work is to make results reproducible), since people work mainly in GUI driven software
My suggestion is the following: You have to help write “landmark papers” that use ODM. The science community follows the path of least resistance and the path of what has worked in the past or for others. Currently, Web ODM is not part of this. And by working with actual users (open-source often does everything from a developer standpoint) we will gain much better insights on what functionality and what help people do actually need.
I sadly can not help with this since I am bound up with work myselve. However a strong and motivated group can and will be able to vastly improve the situation.
TO START (suggestion)
How about a video series explaining every detail a user will need to know. Explain every possible setting in the config of a processing job and show examples of the use and misuse as well as best practice suggestions. When doing this do not brush over anything and cover everything as if it was a full lecture. I am thinking about an old Hak5 approach, where different hosts guide though things, with their own projects and work as examples.
The UAV space is getting more closed down and will continue to do so. Regulatory changes, data security and technology advancements will be handled a lot better by large companies than small ones. And these companies will make sure to secure their market position. - This cange will not happen on it’s own, Web ODM needs help.
