Use-exif not enabled by default - why is this?
I’ve just discovered that the parameter “use-exif” is not enabled by default.
Why is this?
I have assumed “Use exif”, is is used when enab;ed … I often see displaced images(exif not enabled), for the become better aligned, when exif is enabled. the results appear more correct, with the same settings, leaves me wondering why.
use-exif means it processing will use image exif data instead of GCP if there is a GCP file uploaded. If there is not a GCP file then exif gps data will be used by default.
