Hello folks.
I used the --boundary parameter when calling the NodeODM service deployed in Docker, but the task execution failed.
Docker image: opendronemap/nodeodm:gpu
Task init request formdata options:
[{"name":"boundary","value":"{ \"type\": \"FeatureCollection\", \"features\": [ { \"type\": \"Feature\", \"properties\": {}, \"geometry\": { \"type\": \"Polygon\", \"coordinates\": [ [ [ 118.0128572448912, 28.50126887426447 ], [ 118.01247468400081, 28.50130002848917 ], [ 118.01148504550815, 28.5018827137279 ], [ 118.0120997254289, 28.50284532387725 ], [ 118.01207040492928, 28.50351902682331 ], \t\t\t[ 118.01204689122568, 28.50394794657534 ], \t\t\t[ 118.01325225983096, 28.50358009368804 ], \t\t\t[ 118.01373554189047, 28.50316731453679 ], \t\t\t[ 118.01374797683852, 28.50203030949384 ], \t\t\t[ 118.01396506314367, 28.50203525673123 ], \t\t\t[ 118.01394932367025, 28.50149287524119 ], \t\t\t[ 118.01330708056972, 28.50126511130785 ], \t\t\t[ \t\t\t 118.0128572448912, \t\t\t 28.50126887426447 \t\t\t] ] ] } } ] }"}]
Error log:
usage: run.sh [options] <dataset name>
run.py: error: argument --boundary: { type: FeatureCollection, features: [ { type: Feature, properties: {}, geometry: { type: Polygon, coordinates: [ [ [ 118.0128572448912, 28.50126887426447 ], [ 118.01247468400081, 28.50130002848917 ], [ 118.01148504550815, 28.5018827137279 ], [ 118.0120997254289, 28.50284532387725 ], [ 118.01207040492928, 28.50351902682331 ], [ 118.01204689122568, 28.50394794657534 ], [ 118.01325225983096, 28.50358009368804 ], [ 118.01373554189047, 28.50316731453679 ], [ 118.01374797683852, 28.50203030949384 ], [ 118.01396506314367, 28.50203525673123 ], [ 118.01394932367025, 28.50149287524119 ], [ 118.01330708056972, 28.50126511130785 ], [ 118.0128572448912, 28.50126887426447 ] ] ] } } ] } is not a valid JSON string.
How should I pass the --boundary parameter?
