Stitching failing. Any ideas why?
After a bunch of flights with no problems, I was trying some new parameters (to speed up my flights), and now the images are mostly not stitching, but sometimes they are–when I change seemingly insignificant settings in odm (e.g., auto-boundary YES + crop 3 to autoboundary NO + crop 0). Any advice would be appreciated.
I think I need to be clear about how I am taking the photos, as I suspect that this is the source of the problem.
I have a DJI Air-2S, and I am using MapPilotPro to control it. All flights are at 100 m altitude, not adjusted for terrain, in a hilly area, and the flight area is about 35 Ha (chosen to use about 1 battery). I fly a back-and-forth pattern over the same area twice, the first time with a gimbal angle of 5°, the second time with the path rotated 45° and a gimbal angle of 25°. Flight speed is limited to 10 m/s, and I set the ISO so that shutter speed is ≤ 1/1000 s, for a blur ≤ 1 cm. (GSD is about 3 cm for this camera).
Previously, I always did the first flight (gimbal angle 5°) with 85%/85% overlap, and the second flight (gimbal angle 25°) with 65%/65% overlap. The idea, as I understand it, was to use the high overlap to get good geometry, and then second flight to ensure that the resulting reconstruction wasn’t warped due to the low quality lens in the DJI Air 2S. This has worked.
The other day I thought that I could fly a larger area in the same time if I reduced the coverage of the first flight. So I tried flying at 65%/65% for the first and second flights (effective overlap about 75%) and at 75%/75% for the first and second flights (effective overlap about 83%). I have been able to stitch the photos from the first test (65%/65%) twice (once as “Fast Orthophoto”, once as “High”) and stitching failed once (the same settings except auto-boundary off and crop 0). I have not been able to stitch the second test (75%/75%), but depending on the boundary settings it once failed after 6 minutes and once after 6 hours.
I do my stitching on a local linux computer using webodm latest (updated 2024-01-14).
The error message varies, but a typical one from the 65%/65% overlap that failed (console output attached) is:
File "/code/SuperBuild/install/bin/opensfm/opensfm/matching.py", line 680, in match_flann
results, dists = index.knnSearch(f2, 2, params=search_params)
cv2.error: OpenCV(4.5.0) /code/SuperBuild/src/opencv/modules/flann/include/opencv2/flann/kdtree_index.h:470: error: (-215:Assertion failed) result.full() in function 'getNeighbors'
terminate called without an active exception
/code/SuperBuild/install/bin/opensfm/bin/opensfm: line 12: 43712 Aborted                 (core dumped) "$PYTHON" "$DIR"/opensfm_main.py "$@"
Child returned 134
File "/code/stages/odm_app.py", line 82, in execute
File "/code/opendm/types.py", line 438, in run
File "/code/opendm/types.py", line 417, in run
File "/code/stages/run_opensfm.py", line 35, in process
File "/code/opendm/osfm.py", line 436, in feature_matching
self.match_features(rerun)
File "/code/opendm/osfm.py", line 441, in match_features
self.run('match_features')
File "/code/opendm/osfm.py", line 34, in run
system.run('"%s" %s "%s"' %
File "/code/opendm/system.py", line 112, in run
opendm.system.SubprocessException: Child returned 134
The settings from this failed run are:
A temporary link to my photos is here, but they are about 4.3 GB in size.
console.txt (141.7 KB)
what are the specs of your machine?
It processed for me.
trail
Thank you, uplanddog. I am very surprised by your results, but it certainly gives me a different set of problems to look at. (I am currently doing a test of these images at webodm.net, which I probably should have done before posting here).
I am running on a Mac Mini with a 6-core Core i7 processor and 64 GB of RAM and Mint linux. I have done much larger runs on this machine (2,500+ photos) without any problems, so it never occurred to me that it could be a problem with my machine.
However, yesterday the machine “blew up”. It won’t boot into llnux and it tells me to do a fsck, so perhaps there was some incipient problem that interfered with webodm. (I can’t figure out how, but given the coincidence…) It is a dual boot machine, so I can still run Docker under macOS.
It will take me some time to reinstall linux on this machine and do more test runs. But for now, I’ll take your results as indicating the source of my problem, and rely on Docker under macOS or the Lightning Network for a while.
Good luck with the troubleshooting.
Thanks uplanddog for your good thoughts. I have theories as to what is happening, but won’t bore you with them right now.
ok. good luck and let us know of any revelations or resolutions…
