Several issues found in SRT parsing and GPS altitude handling
While working with video + SRT workflows in ODM (especially for RTK / ground-based video use cases), I identified several issues that can lead to loss of precision or incorrect metadata parsing. I’m sharing them briefly with suggested fixes.
Issue 1 – GPS altitude is rounded when written to EXIF
File: opendm/video/video2dataset.py
Altitude values are correctly parsed from the SRT file, but they are rounded to an integer when written to EXIF:
gps_ifd[piexif.GPSIFD.GPSAltitude] = float_to_rational(round(altitude))
# 192.048 -> 192
This causes loss of vertical accuracy, which is critical for RTK and precise ground surveys.
Suggested fix:
gps_ifd[piexif.GPSIFD.GPSAltitude] = float_to_rational(altitude)
or (to preserve millimeter precision with a stable denominator):
gps_ifd[piexif.GPSIFD.GPSAltitude] = float_to_rational(round(altitude * 1000) / 1000)
Issue 2 – Missing comma in shutter regex list
File: opendm/video/srtparser.py
Due to a missing comma, two regex patterns are unintentionally concatenated into a single string:
shutter = match_single([
    "shutter : \d+/(\d+\.?\d*)"
    "SS (\d+\.?\d*)"
], line)
Suggested fix:
    "shutter : \d+/(\d+\.?\d*)",
    "SS (\d+\.?\d*)"
], line)
Issue 3 – Incorrect zero check when parsing latitude/longitude/altitude
The following condition compares a string to an integer and therefore always evaluates to True:
lambda v: float(v) if v != 0 else None
Suggested fix:
fv = float(v)
return fv if fv != 0 else None
Issue 4 – RTK altitude regex only matches integers
The current regex does not capture floating-point RTK altitude values:
("RTK ... (-?\d+)\)", ...)
Suggested fix:
(-?\d+\.?\d*)
These issues mainly affect GPS/Z accuracy and metadata consistency, particularly in high-precision RTK and ground-based video workflows.
I’d be happy to help with testing or preparing a PR if needed.
Thanks for the great work on ODM.
Hi there.. i’ve recently experienced what you say.. i’ve had to do a job in 2 separate times because of the rain (i use a mavic3E+RTK)..
  • The first run has been done with classic setup, taking photo delayed by time 0,X sec each
    For an area of around 28.000sqm and 200m points
  • The second run has been done with (always RTK on) video (video +SRT file ofc)
    Area of 54sqm :sob: and 47m points
Obviously i can’t overlap the two models and probably will need to redo the whole work :-/
(i use webODM 2.8.1)
@Kemal, I think you can open a pull request - information here: Pull requests · OpenDroneMap/ODM · GitHub
Yes, a pull request would be most appreciated. I created the relevant issues on repo:
I’ve submitted a pull request to address the SRT parsing and GPS altitude issues discussed here.
Thanks for the guidance!
Excellent! Thank you. Do you have a good test dataset I could use?
Disregard. I’ll test with this: https://github.com/pierotofy/drone_dataset_dji_video/archive/main.zip
Understood. In my workflow, the video and SRT files are generated using position data from an RTK GNSS receiver. After the update, I will also test it with my own dataset. I can share a sample dataset if needed.
An additional sample dataset would be great. It will be interesting to see the impact with that precision and accuracy of data.
