Rtx 5090 gpu
Is there a known issue with 50 series GPU’s. If so, is there a known work around or driver set that resolves the issue. At this point I cannot create a map without a it failing. Based on the error and research it is an issue with the CUDA driver.
Yes it’s a known issue with about 3 threads on the subject, to process, select the no gou setting
So is there a timeline or focus on a resolution or a way to revert to the motherboard factory GPU
If you set the - no gpu flag and it still fails to process then there is something else at play.
If you take a read of the comments here
Any identified timeline for a resolution
None at this time.
Sorry, where would I set the flag. I found it in the json code, but not sure how to change it from false to true
“domain”: “”,
“help”: “Do not use GPU acceleration, even if it’s available. Default: %(default)s”,
“name”: “no-gpu”,
“value”: “false”,
“type”: “bool”
@uplanddog….Disregard, I found it and that seems to have allowed the map to process with CPU only….thanks for the help
Glad it worked out. The option to use a GPU for processing is nice and will save some time especially for large datasets, but in my experience the quality is not as good as processing with just the CPU.
