Rolling Shutter - Data
Did some testing on my DJI Air 3S. Here is what I came up with, and I tried to add it to the database, but probably did something wrong since I wasn’t even sure what a “Pull Request” was, or how to properly enter data. I completed the initial form with attached picture, but after that, who knows. Maybe someone can use this to put it in correctly? I can send photos also. I also tested telephoto if there is an interest.
‘dji fc9113’: lambda p: (
22 if p.get_capture_megapixels() < 12 else # 12MP 16:9 mode (actual 9.44MP)
30 if p.get_capture_megapixels() < 20 else # 12MP 4:3 mode (actual 12.58MP)
34 if p.get_capture_megapixels() < 45 else # 50MP 16:9 mode (actual 37.75MP)
46 # 50MP 4:3 mode (actual 50.33MP)
), # DJI Air 3S (RAW/DNG 50MP 16:9 34 Lines 37.75 MP actual. 50MP 4:3 45 Lines, 50.33MP actual.)
), # DJI Air 3S (Telephoto FL 19.35 MM 12MP 16:9 16 Lines 9.14MP actual. 12MP 4:3 22 Lines, 12.19MP actual.)
Thanks!
Are you trying to process DNG files?
Make sure you’re using JPEG files.
DNG files are supported by ODM (NEF and RAW too).
Thanks, I wasn’t aware of that.
Is there an advantage to using DNG files over JPG?
Not really, but you do get 16bit orthophotos from them if for some reason you want the additional range of pixel values.
