Hello everyone,
I tried to do a roof inspection and wanted to create a roof as an orthomosaic. Unfortunately, I found that the result via WebODM is not satisfactory in comparison to Pix4D Cloud.
About my flight data:
DJI Mavic 2 Pro
Images shot with 90 degrees
overlap 75/75
flight altitude 25 m
approx. GSD: 0.7 cm
Parameters in WebODM:
crop: 0, dem-decimation: 1, dem-gapfill-steps: 4, dem-resolution: 1, depthmap-resolution: 1000, dsm: true, dtm: true, end-with: odm_orthophoto, ignore-gsd: true, matcher-neighbors: 8, mesh-octree-depth: 12, mesh-size: 1000000, min-num-features: 64000, orthophoto-resolution: 1, pc-filter: 0, pc-quality: high, rerun-from: dataset
Perhaps you can help me to get a better result out of WebODM?
Find some pictures on DroneDB:
https://hub.dronedb.app/r/brisksky/roof-inspection
The Pix4D orthomosaic is much sharper in depth and therefore more suitable for inspection.
Pix4D Cloud still beats us on orthos typically. That’s an area of active research and improvement. That said, there is a lot to do to improve your settings:
Brisksky:
Make a few changes here. Remove ignore-gsd. That will bring sadness. If your GSD is 0.7, you should set your orthophoto-resolution to 0.7 (or better yet let ODM calculate it, which it might calculate it higher). I wouldn’t use pc-filter 0 unless you know you need it: that could cause a lot of noise. Increase the heck out of your matcher-neighbors – maybe 32. You can turn your mesh-octree depth up to 13 (but I wouldn’t go to 14). Turn your feature quality up to ultra as well as your pc quality and don’t directly use depthmap resolution.
Something like this would be an improvement:
crop: 0, dem-resolution: 1.4, dsm: true, dtm: true, matcher-neighbors: 32, mesh-octree-depth: 13, mesh-size: 600000, min-num-features: 64000, pc-quality: ultra, feature-quality: ultra, resize-to: -1
The following are my typical settings which generally don’t need tweaking for many datasets:
auto-boundary: true, dsm: true, feature-quality: ultra, matcher-neighbors: 40, mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 64000, orthophoto-resolution: 1, pc-geometric: true, pc-quality: ultra, rerun-from: dataset, resize-to: -1
Good luck, and let us know what you see! Any screenshots you can share would be good to see.
What I found, ODM orthophotos (sometimes) give similar result with Pix4D, but the GPS accuracy seems Pix4D is better
Let me give an example
Here is public dataset https://www.sensefly.com/education/datasets/?dataset=1419
ODM result 1st
Pix4D 1st
ODM 2nd
Pix4D 2nd
ODM 3rd
Pix4D 3rd
ODM setting
version = 2.7.2 via Docker
OS = MXLinux 19.4
pc-geometric true; pc-quality high; feature-quality high; mesh-size 600k; mesh-octree-depth 12; orthophoto-resolution 2 cm/px; dem-resolution 2 cm/px; dsm true; min-num-features 12k; the rest are default
We’ve got an update just this week that may address this. If you haven’t already: update and rerun. I’d be curious what you see.
Woah interesting
Has it available from Docker with ./webodm.sh update --gpu ?
I haven’t tested GPU, but I assume so.
system
Closed
April 3, 2022, 1:42pm
9
