Please help in Error in "Process exited with code 1"
Hi, I just installed the webobm today in win10, i7, 16G ram,
I try some images. All I used in pix4d filed before. There are multi-bands images including RGBs.
I can’t finish any projects.
First I used couple hundreds images. fail.
Then I reduce the images even to 10, it sill failed.
The error is as below.
Is the problem I don’t install correctly or other pre process required?
My data are in Google Drive. F28 - Google Drive
“Process exited with code 1” means that part of the processing failed. Sometimes it’s a problem with the dataset, sometimes it can be solved by tweaking the Task Options and sometimes it might be a bug! If you need help, upload your images somewhere like DroneDB or Google Drive and open a topic on our community forum, making sure to include a copy of your task’s output. Our awesome contributors will try to help you!
Thank you.
one of 59 images, the logs
INFO] Initializing ODM - Tue Feb 09 01:51:12 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: ultra
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 12
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 18000
[INFO] name: eb718ac9-6799-4542-b2c4-c655a889a220
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/images
[INFO] Loading images database: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/images.json
[INFO] Found 59 usable images
[INFO] Coordinates file already exist: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/odm_georeferencing/coords.txt
[INFO] Parsing SRS header: WGS84 UTM 10N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/opensfm/image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] Detect features already done: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/opensfm/features exists
[WARNING] Match features already done: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/opensfm/matches exists
[WARNING] Found a valid OpenSfM tracks file in: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/opensfm/tracks.csv
[WARNING] Found a valid OpenSfM reconstruction file in: /var/www/data/eb718ac9-6799-4542-b2c4-c655a889a220/opensfm/reconstruction.json
Are you able to process a test dataset such as Brighton Beach ?
If so the installation is probably OK.
Try it now.
Yes. I can finish this sample one.
thank you for your help.
First, the app should be installed correctly. thank you. [pierotofy]
Does webODM provide the NVDI and so on result in muti-bands images?
except the sample one, I don’t success in any images yet.
Do I need to Pre-Process something before loading into webODM?
