Hey ODM community!
I want to compute NDVI and other spectral indices from Phantom 4 Multispectral flights.
What would be the optimal ODM processing settings to obtain valid reflectances (in the range of 0-1) values? I’d appreciate some guidance! At a loss with so many processing options - first time using drone imagery! Pixel values in the bands of the orthomosaic include negative values and other very small ones (like commented in this thread: Multispectral orthomosaic reflectance values). Details on processing options and bands statistics below.
Thanks in advance for your advice and processing tips! Cheers!
For the record, I have also tried --radiometric-calibration camera+sun, but then I get this message: ===== Done, human-readable information to follow… =====
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 3.5.4 documentation
100 - done.
ERROR: LoadError: failed process: Process(docker run --rm -v /Users/ODM_jl/2023-10-31_plot_3_60mts:/dataset opendronemap/odm /dataset --min-num-features 24000 --orthophoto-resolution 1 --dem-resolution 1 --radiometric-calibration camera+sun --texturing-skip-global-seam-leveling --orthophoto-no-tiled --orthophoto-compression DEFLATE --skip-3dmodel --use-exif, ProcessExited(1)) [1]15:42
Band stats are:
Band 1 * STATISTICS_APPROXIMATE=YES
STATISTICS_MAXIMUM=0.00034588208654895
STATISTICS_MEAN=4.1638241700016e-05
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=3.9477168852232e-05
STATISTICS_VALID_PERCENT=100
Scale: 1
Offset: 0
Band 2 * STATISTICS_APPROXIMATE=YES -
STATISTICS_MAXIMUM=0.00023238248832058
STATISTICS_MEAN=4.305794611104e-05
STATISTICS_STDDEV=3.0363897633484e-05
Scale: 1
Offset: 0
Band 3 * STATISTICS_APPROXIMATE=YES -
STATISTICS_MAXIMUM=9.4602539320476e-05
STATISTICS_MEAN=1.9053275863524e-05
STATISTICS_STDDEV=1.234490200541e-05
Scale: 1
Offset: 0
Band 4 * STATISTICS_APPROXIMATE=YES -
STATISTICS_MAXIMUM=0.0004375149437692
STATISTICS_MEAN=9.3793929263158e-05
STATISTICS_MINIMUM=-3.2635998650221e-05
STATISTICS_STDDEV=6.0245358047185e-05
Scale: 1
Offset: 0
Band 5 * STATISTICS_APPROXIMATE=YES -
STATISTICS_MAXIMUM=0.0004199493851047
STATISTICS_MEAN=8.9436464517462e-05
STATISTICS_MINIMUM=-4.1719085857039e-05
STATISTICS_STDDEV=5.8862251313409e-05
Scale: 1
Offset: 0
Band 6 * STATISTICS_APPROXIMATE=YES -
STATISTICS_MAXIMUM=255
STATISTICS_MEAN=224.74428159194
STATISTICS_STDDEV=82.46089799208
Scale: 1
Offset: 0
