Does anyone have an idea why this is happening? I am new to WebODM so this is probably just something small that I am missing.
I’m attempting to use the webodm lightning API in order to process and download images and point clouds, I have a file called process.py in which there is the following (slightly redacted) code:
from pyodm import Node
import glob
n = Node('spark1.webodm.net', 443, 'MY_TOKEN')
task = n.create_task(glob.glob("D:\\Documents\\University of Pretoria\\COS301\\Capstone Project\\Test Imagery"), {'dsm': True})
task.wait_for_completion()
task.download_assets("results")
When I try to run this, I get the following error message stream. I don’t know why this is the case and I have also tried running it as administrator but I get the same issue.
This is running on Windows 11 Home edition and within a python 3.10.5 virtual environment with the following libraries:
certifi==2022.6.15
charset-normalizer==2.1.0
idna==3.3
pyodm==1.5.9
requests==2.28.1
requests-toolbelt==0.9.1
urllib3==1.26.10
Any ideas? The error seems to originate from the pyodm/api.py file. Is the problem in that api.py file or am I using the API incorrectly? Thanks.
