Unsurprisingly, I have a lot of photogrammetric reconstructions of my house. And I just bought a very affordable electric car. So: using the fuel cost savings from my new purchase, I plan to deploy a solar array on my house. It should be enough to offset the car and part of the household electrical costs, so let’s find out for sure.
First a disclaimer: there are much simpler ways to do the estimates I am doing, but it is fun to do them on data I have already collected and processed.
First of all, visualization settings: I like to do these measurements in the 3D view and punish my embedded graphics card by turning the “Point budget” up all the way, and enable “High Quality” splats. That said, I find that “High Quality” is incompatible with orthographic views (possible bug? could someone test on their browser?), so we can toggle that off when we do orthographic views:
First, let’s measure the rooftop angle, and the size of the roof. Be careful when doing this: it’s easy to pick a point that is not on the roof, but on the ground, so after you place your points for measurement, be sure to give the model a spin to double check point placement for your measurements.
It looks like a roof angle of 39° with sides of 4.86m and 7.68m. Super! We are more than halfway there.
Now we switch to orthographic view (and switch off High Quality splats) so that we can measure the angle of my curb.
Why my curb? Well, the roofline parallels the curb, so I can make sure all the points are largely in a single plane if I measure the curb, which is difficult or impossible on the roof itself. Wow: also about 39°. Now we have what we need for our calculations.
Let’s head over to Global Solar Atlas, find where we are in the world, and plug the data we need in.
Given the dimensions of my roof, I might be able to squeeze a 6kWp system on there, so assuming that, and plugging in the PV panel tilt (my roof angle) and my house’s azimuth (180 + 39°), we should get a pretty robust estimate of how much power we can generate on top of my house
Click apply and check the average MWh I can create, and we can get around 7MWh per year:
Cool! Now the original question: can I drive my car on that? Assuming I’m driving 10,000 miles/year on my (not the most efficient used) BEV, I can expect to consume about 4MWh per year. In short, I’ll be running a surplus that will help offset other electrical usage in the house.
Now to figure out how to build a garage with panels for the rest of my electrical consumption… .
