Negative values in bands after calibration image?
Hi community, I have recently been using images from the Phantom 4 multispectral with webodm, however when I perform the ND calibration to surface reflectance values with the :
  • Camera
  • Camera + sun
I have negative value in the calibration bands, this is very strange because the reflectance value is 0 - 1, correct?
For this process I have been using WebODM Lightning
Finally here put my image set used:
Here an example of the green band
Was Piero’s tip on GitHub correct?
Indeed, this error was solved thanks to Piero’s suppo :point_right: here.
Thanks for everything!
Hmm…
I wonder if we might need to revisit the Multispectral preset and maybe include the --texture-skip-global-seam-leveling flag…
