This is the script I used to install ODM and NodeODM on ubuntu 18.04
I have processed one small data-set and it seems working fine.
#!/bin/bash
install() {
sudo apt update -y
sudo apt upgrade -y
sudo apt install -y virtualenv curl python-setuptools build-essential gcc g++ cmake python3-dev python-virtualenv binutils libproj-dev git
cd /
sudo git clone --depth 1 https://github.com/OpenDroneMap/OpenDroneMap.git code
sudo git clone --depth 1 https://github.com/OpenDroneMap/node-OpenDroneMap.git www
sudo chown $(whoami) -R /www /code
cd /code
## Set up library paths
export PYTHONPATH=$RUNPATH/SuperBuild/install/lib/python2.7/dist-packages:$RUNPATH/SuperBuild/src/opensfm:$PYTHONPATH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$RUNPATH/SuperBuild/install/lib
## Before installing
echo "Updating the system"
sudo add-apt-repository -y ppa:ubuntugis/ubuntugis-unstable
echo "Installing Required Requisites"
sudo apt-get install -y -qq build-essential \
git \
cmake \
python-pip \
libgdal-dev \
gdal-bin \
libgeotiff-dev \
pkg-config \
libjsoncpp-dev \
python-gdal \
grass-core \
libssl-dev \
liblas-bin \
swig3.0 \
python-wheel \
libboost-log-dev
echo "Installing OpenCV Dependencies"
sudo apt-get install -y -qq libgtk2.0-dev \
libavcodec-dev \
libavformat-dev \
libswscale-dev \
python-dev \
libtbb2 \
libtbb-dev \
libjpeg-dev \
libpng-dev \
libtiff-dev \
libflann-dev \
libproj-dev \
libxext-dev \
liblapack-dev \
libeigen3-dev \
libvtk6-dev
sudo add-apt-repository "deb http://security.ubuntu.com/ubuntu xenial-security main"
sudo apt-get update
sudo apt-get install -y -qq libjasper1 \
libjasper-dev
echo "Installing OpenSfM Dependencies"
sudo apt-get install -y -qq libgoogle-glog-dev \
libsuitesparse-dev \
libboost-filesystem-dev \
libboost-iostreams-dev \
libboost-regex-dev \
libboost-python-dev \
libboost-date-time-dev \
libboost-thread-dev
pip install -r "/code/requirements.txt"
# Fix: /usr/local/lib/python2.7/dist-packages/requests/__init__.py:83: RequestsDependencyWarning: Old version of cryptography ([1, 2, 3]) may cause slowdown.
pip install --upgrade cryptography
python -m easy_install --upgrade pyOpenSSL
echo "Compiling SuperBuild"
cd /code/SuperBuild
mkdir -p build && cd build
cmake .. && make -j4
echo "Compiling build"
cd /code
sudo ln -s /code/SuperBuild/install/bin/entwine /usr/bin/entwine
sudo ln -s /code/SuperBuild/install/bin/pdal /usr/bin/pdal
cd ~
sudo curl --silent --location https://deb.nodesource.com/setup_10.x | sudo bash -
sudo apt install -y nodejs python-gdal
cd /www
npm install
sudo useradd -m odm
sudo groupadd odm
sudo usermod -aG odm odm
sudo chown -R odm:odm /code /www /home/odm
sudo systemctl enable /www/services/nodeodm.service
sudo service nodeodm start
echo "Configuration Finished"
uninstall() {
echo "Removing SuperBuild and build directories"
cd /code/SuperBuild
rm -rfv build src download install
cd ../
rm -rfv build
reinstall() {
echo "Reinstalling ODM modules"
uninstall
install
usage() {
echo "Usage:"
echo "bash configure.sh <install|update|uninstall|help> [nproc]"
echo "Subcommands:"
echo " install"
echo " Installs all dependencies and modules for running OpenDroneMap"
echo " reinstall"
echo " Removes SuperBuild and build modules, then re-installs them. Note this does not update OpenDroneMap to the latest version. "
echo " uninstall"
echo " Removes SuperBuild and build modules. Does not uninstall dependencies"
echo " help"
echo " Displays this message"
echo "[nproc] is an optional argument that can set the number of processes for the make -j tag. By default it uses $(nproc)"
if [[ $1 =~ ^(install|reinstall|uninstall|usage)$ ]]; then
RUNPATH="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
"$1"
else
echo "Invalid instructions." >&2
usage
exit 1
fi
You have to edit /www/services/nodeodm.service and on the line 10 , you have to add “–odm_path /code”
So the line become:
ExecStart=/usr/bin/node index.js --odm_path /code
ODM is installed at /code
NodeODM is installed at /www
Just copy the scrip in home dir , make it executable and run it:
sudo ./configure.sh install
I am far from linux/code guru, so bear with me and use/modify it as you like!
