Multispectral Analysis
The four bands of the Sequoia camera are Green, Red, Red-Edge, and Near-Infrared, so I have to select “GRReN” as a filter pop-ups in the Layers of Plant Health view of the WebODM, but it does not appear as an option.
The closest is “RGBN”, but that uses Green and Near-Infrared instead of Red and Near-Infrared to calculate NDVI.
Editing “formulas.py” might help, but for those who use the Sequoia camera, can’t you make it supported in the official version ?
One more point.
If you can read the output of the Sequoia camera’s solar radiation sensor, you can calculate the reflectance accurately for each band without having to take a picture of the calibration plate every time.
However, the current version of OpenDroneMap does not seem to be able to read the values of the Sequoia camera’s solar radiation sensor even if “Radiometric-calibration=camera+sun”.
Therefore, before processing the captured multi-band images with OpenDroneMap, I used my own pre-processing program to read the solar radiation sensor values and shutter speed included in the Exif area, rewrite the intensity of the image data, and then process the modified image data with “Radiometric-Calibration=None” in OpenDroneMap to obtain accurate reflectance.
This procedure is complicated and should be incorporated into OpenDroneMap, is it possible?
I am not familiar with Python programs, so it will be a lot of work for me personally.
Great questions!
Have you looked at formulas.py? If so, if you open a Pull Request for the change you need, you can help us make it official for everyone!
As for the second part, thanks for surfacing that the calibration routine isn’t working as expected with the Spectral Sensor for the Sequioa.
What language is your program written in?
I can rewrite the 6th item in “camera_filters” from ‘RGBN’ to ‘GRReN’ using a text editor, but I don’t know how to rebuild WebODM with the modified source code.
So, before using WebODM, I added a pre-processing program to swap the RED and GREEN image data so that correct NDVI values are obtained.
However, I don’t think this is a common solution.
Currently, it is almost impossible for people using Sequoia cameras to get the correct NDVI maps with current version of WebODM.
It is hoped that the WebODM will be updated to support the Sequoia cameras.
The programming environment I use is WaveMetrics IgorPro, and Igor XOP.
It does not have many users in general, but it is often used in the field of spectroscopy.
If you need faster calculation speed, you can add custom XOP modules written in c++.
You shouldn’t have to compile it. If you’re fairly certain you did it right, open the pull request and GitHub actions will take care of the build.
I created a GitHub account, but I have no idea how to open a “pull request”.
What do I have to do after clicking the “Create Pull Request” button ?
It looks like I have to choose a branch, but how do I create a branch ?
I don’t think I have enough experience with GitHub yet …
Start by clicking the “Fork” button:
Once you are working in your own fork which will show your own name (it’ll look like this):
Find the formulas.py, Edit it using the built-in editor:
Save the changes, then go back to the root of your repository:
Hit that Contribute button, then Create A Pull Request:
After forking, I edited “formulas.py” and simply replaced ‘RGBN’ with ‘GRReN’, and then made a “pull request”.
I would like to run the special WebODM built with the modified source code to see if it works as intended.
What do I need to do next?
Help !!!
After completing the “pull request”, Checks shows that the build and test run appear to have been successful.
Cloning WebODM from my fork of GitHub confirms that the file “formulas.py” in my harddisk have indeed been modified. (“GRReN” is inserted after “RGBN”)
  git clone https://github.com/<my-git-account-name>/WebODM
On top of that, I ran “. /webodm.sh start” and ran WebODM, but the additions (“GRReN”) did not appear in the filter choices.
I seem to have made a mistake somewhere, can anyone please tell me what I should do ?
Thanks.
