Looking to Trust Volume Calculations
I’m looking to trust volume calculations of gravel stockpiles. The reason I question the calculations is: I did a measurement of a flat area with no volume on it, and the calculations came in at 900 cubic meters.
It’s hard to know what you are seeing without a test dataset or steps to reproduce. Folks using ODM have seen accuracies within typical photogrammetry ranges, but specifics matter with respect to data collection.
I would recommend measuring a stockpile with surveyed volume as a test, and take a look at the tutorials on stockpile volume here:
https://docs.opendronemap.org/tutorials/#measuring-stockpile-volume
Edit, just adding this from the docs:
Expected accuracy
For carefully planned and executed projects, and specially when GSD is less than 1 cm, the expected accuracy should be in the range of 1% to 2%. The resulting accuracy is comparable to the commercially available photogrammetry software and the obtained using survey grade GNSS equipment.
I should edit that to say “closed source photogrammetry software”….
Thank you for your reply and for the link.
Qgis has a good plug-in for volumes. I’ve compared it to my geodetic cad software at work and it’s very accurate.
Might be something for you.
