Issues with Postgres when moving docker to other disk mount
I have openSuse installed in a 40GB partition .
Docker by default uses /var/lib/docker/ to create volumes etc , which means i can only put a couple of images before i fill up the partition.
I edit the /etc/docker/daemon.json with “data-root”: “/lots/of/disk/space,”, restarted docker create all the volumes .
i run ./webodm.sh start it downloads /creates all the images and then greats me with db exited with code 1
db | chmod: changing permissions of '/var/lib/postgresql/data': Operation not permitted broker | 1:C 08 Jan 2022 12:14:13.167 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo broker | 1:C 08 Jan 2022 12:14:13.167 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=1, just started broker | 1:C 08 Jan 2022 12:14:13.167 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf db | ******************************************************************************** db | WARNING: POSTGRES_HOST_AUTH_METHOD has been set to "trust". This will allow db | anyone with access to the Postgres port to access your database without db | a password, even if POSTGRES_PASSWORD is set. See PostgreSQL db | documentation about "trust": db | https://www.postgresql.org/docs/current/auth-trust.html db | In Docker's default configuration, this is effectively any other db | container on the same system. db | db | It is not recommended to use POSTGRES_HOST_AUTH_METHOD=trust. Replace db | it with "-e POSTGRES_PASSWORD=password" instead to set a password in db | "docker run". db | ******************************************************************************** db | The files belonging to this database system will be owned by user "postgres". db | This user must also own the server process. db | db | The database cluster will be initialized with locale "en_US.utf8". db | The default database encoding has accordingly been set to "UTF8". db | The default text search configuration will be set to "english". db | db | Data page checksums are disabled. db | node-odm_1 | info: Authentication using NoTokenRequired node-odm_1 | info: Listening on 0.0.0.0:6367 UDP for progress updates worker | psql: error: could not translate host name "db" to address: Name or service not known broker | 1:M 08 Jan 2022 12:14:13.167 * monotonic clock: POSIX clock_gettime worker | Postgres is unavailable - sleeping worker | psql: error: could not connect to server: No route to host worker | Is the server running on host "db" (172.19.0.3) and accepting worker | TCP/IP connections on port 5432? worker | Postgres is unavailable - sleeping db | fixing permissions on existing directory /var/lib/postgresql/data ... initdb: could not change permissions of directory "/var/lib/postgresql/data": Operation not permitted broker | 1:M 08 Jan 2022 12:14:13.167 * Running mode=standalone, port=6379. node-odm_1 | info: No tasks dump found broker | 1:M 08 Jan 2022 12:14:13.167 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128. broker | 1:M 08 Jan 2022 12:14:13.167 # Server initialized broker | 1:M 08 Jan 2022 12:14:13.167 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect. node-odm_1 | info: Checking for orphaned directories to be removed... node-odm_1 | info: Server has started on port 3000 broker | 1:M 08 Jan 2022 12:14:13.177 * Ready to accept connections worker | psql: error: could not connect to server: Connection refused worker | Is the server running on host "db" (172.19.0.3) and accepting worker | TCP/IP connections on port 5432? worker | Postgres is unavailable - sleeping db exited with code 1 worker | psql: error: could not translate host name "db" to address: Name or service not known worker | Postgres is unavailable - sleeping webapp | psql: error: could not connect to server: Connection refused webapp | Is the server running on host "db" (172.19.0.3) and accepting webapp | TCP/IP connections on port 5432? webapp | Postgres is unavailable - sleeping db | chmod: changing permissions of '/var/lib/postgresql/data': Operation not permitted db | ******************************************************************************** db | WARNING: POSTGRES_HOST_AUTH_METHOD has been set to "trust". This will allow db | anyone with access to the Postgres port to access your database without db | a password, even if POSTGRES_PASSWORD is set. See PostgreSQL db | documentation about "trust": db | https://www.postgresql.org/docs/current/auth-trust.html db | In Docker's default configuration, this is effectively any other db | container on the same system. db | db | It is not recommended to use POSTGRES_HOST_AUTH_METHOD=trust. Replace db | it with "-e POSTGRES_PASSWORD=password" instead to set a password in db | "docker run". db | ******************************************************************************** db | The files belonging to this database system will be owned by user "postgres". db | This user must also own the server process. db | db | The database cluster will be initialized with locale "en_US.utf8". db | The default database encoding has accordingly been set to "UTF8". db | The default text search configuration will be set to "english". db | db | Data page checksums are disabled. db | db | fixing permissions on existing directory /var/lib/postgresql/data ... initdb: could not change permissions of directory "/var/lib/postgresql/data": Operation not permitted worker | psql: error: could not connect to server: Connection refused worker | Is the server running on host "db" (172.19.0.3) and accepting worker | TCP/IP connections on port 5432? worker | Postgres is unavailable - sleeping webapp | psql: error: could not translate host name "db" to address: Name or service not known webapp | Postgres is unavailable - sleeping worker | psql: error: could not translate host name "db" to address: Name or service not known worker | Postgres is unavailable - sleeping db | chmod: changing permissions of '/var/lib/postgresql/data': Operation not permitted db | ******************************************************************************** db | WARNING: POSTGRES_HOST_AUTH_METHOD has been set to "trust". This will allow db | anyone with access to the Postgres port to access your database without db | a password, even if POSTGRES_PASSWORD is set. See PostgreSQL db | documentation about "trust": db | https://www.postgresql.org/docs/current/auth-trust.html db | In Docker's default configuration, this is effectively any other db | container on the same system. db | db | It is not recommended to use POSTGRES_HOST_AUTH_METHOD=trust. Replace db | it with "-e POSTGRES_PASSWORD=password" instead to set a password in db | "docker run". db | ******************************************************************************** db | The files belonging to this database system will be owned by user "postgres". db | This user must also own the server process. db | db | The database cluster will be initialized with locale "en_US.utf8". db | The default database encoding has accordingly been set to "UTF8". db | The default text search configuration will be set to "english". db | db | Data page checksums are disabled. db | db | fixing permissions on existing directory /var/lib/postgresql/data ... initdb: could not change permissions of directory "/var/lib/postgresql/data": Operation not permitted db exited with code 1 db | chmod: changing permissions of '/var/lib/postgresql/data': Operation not permitted db | ******************************************************************************** db | WARNING: POSTGRES_HOST_AUTH_METHOD has been set to "trust". This will allow db | anyone with access to the Postgres port to access your database without db | a password, even if POSTGRES_PASSWORD is set. See PostgreSQL db | documentation about "trust": db | https://www.postgresql.org/docs/current/auth-trust.html db | In Docker's default configuration, this is effectively any other db | container on the same system. db | db | It is not recommended to use POSTGRES_HOST_AUTH_METHOD=trust. Replace db | it with "-e POSTGRES_PASSWORD=password" instead to set a password in db | "docker run". db | ******************************************************************************** db | The files belonging to this database system will be owned by user "postgres". db | This user must also own the server process. db | db | The database cluster will be initialized with locale "en_US.utf8". db | The default database encoding has accordingly been set to "UTF8". db | The default text search configuration will be set to "english". db | db | Data page checksums are disabled. db | db | fixing permissions on existing directory /var/lib/postgresql/data ... initdb: could not change permissions of directory "/var/lib/postgresql/data": Operation not permitted
Is there a remedy to that ? (that folder doesnt exist btw “/var/lib/postgresql/”)
Am i doing this wrong ? is there a better way to make webodm and its paraphernalia run from an other mount ?
Thank you for your time,
Best!
Sorry for the trouble.
I don’t have much hands-on with redirecting the mounts, but could you give us a bit more detail about your system?
How much RAM? How much SWAP?
Hello Saijin,
32GB ram, 2.2 GB swap partition , 5800x cpu.
thank you for your reply,
Best!
Personally I use ubuntu mate on a 128gb ssd as my OS drive which is not a lot of space for ODM. when starting up webodm.sh there is a flag you can use to move the media dir to another drive if you have that available. EG. ./webodm.sh start --media-dir /media/yourdrive/odm this will move the assets to that directory however there is still data that gets stored in your home directory. I have found that the -optimize disk space option works well to keep disk usage of the home directory low. another option is within linux is to move the home directory to a bigger drive if possible… hope this helps…
Hello uplanddog,
yep always have my users in an other mount (other physical disk)
and i do use the --media-dir still docker goes to your /var/lib/docker/ and by default it tries to create a volume of 100GB. That volume you can change , webodm just doesnt like it :D.
I think if it was in a repo like rest of linux software it would save people a bit a headache :smiley:
Thank you for your reply,
Best!
I moved the docker directory off my OS drive as well. This is the directions I found that worked perfectly for my ubuntu distro: https://linuxconfig.org/how-to-move-docker-s-default-var-lib-docker-to-another-directory-on-ubuntu-debian-linux
Not saying no, but my thoughts on this are here:
If you can help contribute a port and maintain it, it’d be 100% a very welcome contribution! If you know Flatpak, we can get even wider coverage and closer to native!
