It is not supported yet, but here is my simple local extension that allows just that. Maybe some proper programmer can implement this later to the pyodm.
import pyodm
#%% Connect to the NodeODM server
# Address of the NodeODM instance. Must start with "http://"
node_url = "http://localhost:3000"
# Create a node object
node = pyodm.Node.from_url(node_url)
# Make sure the node is usable for us.
try:
# ask the status of the node
node_info = node.info()
except Exception as err:
raise ConnectionError(
f"NodeODM server cannot be connected to in address: {node_url}"
print(f"Connected to NodeODM server at address: {node_url}")
print("Node details:")
print(vars(node_info))
#%% Add custom create_task_using_zipurl() function to the node
def create_task_using_zipurl(self, zipurl, options={}, name=None, progress_callback=None, skip_post_processing=False, webhook=None, outputs=[], parallel_uploads=10, max_retries=5, retry_timeout=5):
"""Start processing a new task.
At a minimum you need to pass a list of image paths. All other parameters are optional.
>>> n = Node('localhost', 3000)
>>> t = n.create_task_using_zipurl("https://my_web_service.com/images.zip", \
{'orthophoto-resolution': 2, 'dsm': True})
>>> info = t.info()
>>> info.status
<TaskStatus.RUNNING: 20>
>>> info.last_error
>>> t.info().images_count
2
>>> t.output()[0:2]
['DJI_0131.JPG - DJI_0313.JPG has 1 candidate matches', 'DJI_0131.JPG - DJI_0177.JPG has 3 candidate matches']
Args:
zipurl (str): URL to a ZIP file containing the images.
options (dict): options to use, for example {'orthophoto-resolution': 3, ...}
name (str): name for the task
progress_callback (function): callback reporting upload progress percentage
skip_post_processing (bool): When true, skips generation of map tiles, derivate assets, point cloud tiles.
webhook (str): Optional URL to call when processing has ended (either successfully or unsuccessfully).
outputs (list): Optional paths relative to the project directory that should be included in the all.zip result file, overriding the default behavior.
parallel_uploads (int): Number of parallel uploads.
max_retries (int): Number of attempts to make before giving up on a file upload.
retry_timeout (int): Wait at least these many seconds before attempting to upload a file a second time, multiplied by the retry number.
Returns:
:func:`~Task`
# Do the pyodm imports
from pyodm.types import NodeOption, NodeInfo, TaskInfo, TaskStatus
from pyodm.exceptions import NodeConnectionError, NodeResponseError, NodeServerError, TaskFailedError, OdmError, RangeNotAvailableError
from pyodm.utils import MultipartEncoder, options_to_json, AtomicCounter
from requests_toolbelt.multipart import encoder
if not self.version_greater_or_equal_than("1.4.0"):
return self.create_task_fallback(files, options, name, progress_callback)
fields = {
'name': name,
'options': options_to_json(options),
fields['zipurl'] = zipurl
if skip_post_processing:
fields['skipPostProcessing'] = 'true'
if webhook is not None:
fields['webhook'] = webhook
if outputs:
fields['outputs'] = json.dumps(outputs)
e = MultipartEncoder(fields=fields)
result = self.post('/task/new', data=e, headers={'Content-Type': e.content_type})
if isinstance(result, dict) and 'error' in result:
raise NodeResponseError(result['error'])
return self.handle_task_new_response(result)
# Bind the zipurl function to the pyodm node-object
from types import MethodType
node.create_task_using_zipurl = MethodType(create_task_using_zipurl, node)
#%% Send a task to the node using zipurl
# Define URL to a ZIP file containing the image files
# Optionally use allas.create_presigned_download_url() to create URL to non-public databucket.
zipurl = "https://myserver.com/myimages.zip"
print('Sending task with ZIPURL:')
# task = create_task_using_zipurl(node, zipurl)
task = node.create_task_using_zipurl(zipurl)
print(task.info())
