Not able to conduct install as directed…
- Windows users should install Docker Desktop and 1) make sure Linux containers are enabled (Switch to Linux Containers…), 2) give Docker enough CPUs (default 2) and RAM (>4Gb, 16Gb better but leave some for Windows) by going to Settings – Advanced, and 3) select where on your hard drive you want virtual hard drives to reside (Settings – Advanced – Images & Volumes).
Fresh New Install Jan 12 2023
- Docker does not offer option to enable linux containers from what I can tell
- Resources Advanced
You are using the WSL 2 backend, so resource limits are managed by Windows.
You can configure limits on the memory, CPU, and swap size allocated to WSL 2 in a .wslconfig file.
Git
MASH@DESKTOP-XXXXX MINGW64 ~
$ git clone GitHub - OpenDroneMap/WebODM: User-friendly, commercial-grade software for processing aerial imagery. 🛩 --config core.autocrlf=input --depth 1
fatal: destination path ‘WebODM’ already exists and is not an empty directory.
