I am having issues with starting the program. i dont have a firewall but i gave maxed out the number of attempts to open. it said to share the logs? here we go. I am not great when it comes to this side of computers and would appreciate the help
“Booting WebODM 2.5.6 build 107…”
“Trying to connect to NodeODM localhost:29301…”
“nodeodm: (node:10632) NOTE: The AWS SDK for JavaScript (v2) will enter maintenance mode\non September 8, 2024 and reach end-of-support on September 8, 2025.\n\nPlease migrate your code to use AWS SDK for JavaScript (v3).\nFor more information, check blog post at https://a.co/cUPnyil\n”
“nodeodm: info: Authentication using SimpleToken\r\n”
“nodeodm: info: Listening on 0.0.0.0:6367 UDP for progress updates\r\n”
“nodeodm: info: Initialized 0 tasks\r\n”
“nodeodm: info: Checking for orphaned directories to be removed…\r\n”
“nodeodm: info: Server has started on port 29301\r\n”
“Connected to NodeODM 2.2.3”
“(node:24552) UnhandledPromiseRejectionWarning: undefined”
“(node:24552) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)”
“(node:24552) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.”
“redis-server: exited with code -4058”
