Hubsan Zino Mini and Mini Pro
I hope this question is not disallowed …
I am trying to produce maps using these Hubsan Zino Mini drones, but it’s not easy.
Are there others, in this community, attempting to produce maps using the Hubsan mini products?
I hoping someone has found a work-a-round to take photos, along a line, every 2 or 3 seconds, automatically.
SURV
I’m not familiar with the Hubsan drones, but if they support waypoint flights, you might consider making a waypoint for each camera position. Flight planning software like Ancient Land can export the path to a text file. Maybe with some manipulation you can get something workable. Its not the elegant solution you want, but it might be a possible work around.
Best of luck m
