Hi!
I’m not sure if this has been asked before, but I was wondering how I might go about running multiple instances of WebODM on the same machine. I need to use it for 2 users that cannot have access to each other’s data at all. both users will get the web interface but no terminal access. What’s the proper procedure? Bonus points if we can point the second instance at a second hard drive but use the same processing node so it will actually queue properly and not blow up the server.
Is splitting the system into two virtual machines an option? You can use VMware vSphere ESXi (can get free license from them), or virtualbox
The use case is of a commercial nature and I can’t pay for VMware yet. Virtualbox can’t run nested because of the VT-x limitations. Cant pass through multiple VMs at once.
To run the second WebODM instance on same machine - you should:
- clone WebODM to folder with different name (not WebODM, because docker takes network name from folder name).
- change all 4 container_name fields in docker-compose.yml (for example, db → db_dev, etc)
- Run ./webodm.sh start on different port (–port 8100, for example)
