How to generate ndvi index
HI, i m begginer…
how to generate ndvi index … if I already have two images (NIR and RED), but I don’t know how to proceed.
thank you
Oh, fun!
Let’s start with what camera and filter gave you those images.
micasense altum - 6 band (blue, green.red,nir,ir,thermal)
Excellent. This can be accomplished in many ways. Are you looking to do this within ODM, or are you okay using other tools like QGIS?
in the qgis software I already managed, but I would like to use the ODM platform
Saijin_Naib: I am looking at a drone that sensor has NIR, green, and red bands. The images are saved as 3 tiff images. Image1.tif is the NIR band, Image2.tif is the green band, and Image3.tif is the red band. Each each band is a tiff file. How do you make an orthomosaic using 3 tiff images for each photo site? Do the 3 original tiffs need to be combined into 1 tiff with 3 bands ( NIR, G, & R )?
No, you should not need to merge them, if they are tagged properly, WebODM should read the tags from the images and group them accordingly.
Thank you.
I have attempted to run the images as they are and WebODM messaged “Cannot process dataset”.
The images are labeled: “XACT0221.TIF, XACT0222.TIF, XACT0223.TIF, XACTO231.TIF, XACT0232.TIF, XACT0233.TIF, XACT0241.TIF, XACT0242.TIF, XACTO243.TIF, … XACTO371.TIF, XACT0372.TIF, and XACT0373.TIF”. The last digit is the band with 3 bands (1 Green, 2 Red, and 3 NIR). The image site is the first 3 digits starting with “0”.
What file structure is WebODM looking for when processing multispectral imagery?
It is looking to associate the images with one another by the EXIF tags.
What sensor are you using?
XACTI CX-GB3000 is the camera. It produces a Red tiff, Green tiff, and an Near IR tiff. So there are 3 separate tiff images instead of a tiff image with 3 bands.
Camera Specs: fl=10mm, 2720 x 1815, Bit depth 16, f/4, exposure 1/2000 sec, Max aperture 2.97.
Do the EXIF for each image call out the bandname properly?
Here is the EXIF data a green band tiff: Filename - XACT0221.TIF
ImageWidth - 2720
ImageLength - 1814
BitsPerSample -
Compression - 1 (None)
PhotometricInterpretation - 1
Make - XACTI
Model - CX-GB300
StripOffset - 196608
Orientation - Top left
SamplesPerPixel - 1
RowsPerStrip - 1814
StripByteCount - 9868160
XResolution - 72
YResolution - 72
PlanarConfiguration - 1
ResolutionUnit - Inch
Software - 1.08
DateTime - 2024:01:19 03:13:42
ExifOffset - 2384
ExposureTime - 1/2000 seconds
FNumber - 5.60
ExposureProgram - Shutter priority
ISOSpeedRatings - 400
DateTimeOriginal - 2024:01:19 03:13:42
DateTimeDigitized - 2024:01:19 03:13:42
ApertureValue - F 5.60
ExposureBiasValue - 0.00
MaxApertureValue - F 2.80
SubjectDistance - 3.91 m
FocalLength - 10.20 mm
ExifImageWidth - 2720
ExifImageHeight - 1814
FocalPlaneXResolution - 2083
FocalPlaneYResolution - 2083
FocalPlaneResolutionUnit - Centimeter
White Balance - Manual
FocalLengthIn35mmFilm - 28 mm
Serial Number - CXM001C00064
GPS information: -
GPSVersionID - 2.3.0.0
GPSLatitudeRef - N
GPSLatitude - 34 11 20.12532 (34.188924)
GPSLongitudeRef - W
GPSLongitude - 118 13 0.756839 (118.216877)
GPSAltitudeRef - Sea level
GPSAltitude - 438.49 m
GPSTimeStamp - 18 14 21.083
GPSDateStamp - 2024:01:18
Maker Note (Vendor): -
I do not see any mention of a color or band but, I am not sure what I am looking for. This is the first time I have used NIR imagery.
What is the EXIF field that designates the image’s band?
do you have a NIR band image that I can look over the EXIF data. I have run the 3 separate images in webODM and made 3 mosaics (Red, Green, and NIR). They overlay in Qgis but not able to generate a nice psuedo color image with them.
There should be a Band field in the EXIF.
exiftool IMG_180822_135805_0467_NIR.TIF
ExifTool Version Number         : 12.87
File Name                       : IMG_180822_135805_0467_NIR.TIF
Directory                       : .
File Size                       : 2.5 MB
File Modification Date/Time     : 2019:11:22 09:00:34-05:00
File Access Date/Time           : 2024:10:17 01:16:48-04:00
File Inode Change Date/Time     : 2024:10:17 01:16:27-04:00
File Permissions                : -rwxr-xr-x
File Type                       : TIFF
File Type Extension             : tif
MIME Type                       : image/tiff
Exif Byte Order                 : Little-endian (Intel, II)
Image Width                     : 1280
Image Height                    : 960
Bits Per Sample                 : 16
Compression                     : Uncompressed
Photometric Interpretation      : BlackIsZero
Image Description               : 790 nm
Make                            : Parrot
Camera Model Name               : Sequoia
Strip Offsets                   : 8
Orientation                     : Rotate 180
Samples Per Pixel               : 1
Strip Byte Counts               : 2457600
Min Sample Value                : 0
Planar Configuration            : Chunky
Software                        : v1.5.0
Modify Date                     : 2018:08:22 13:58:05
Rig Name                        : Sequoia
Rig Camera Index                : 3
Yaw                             : -57.306736
Pitch                           : 28.387545
Roll                            : 1.071882
Band Gain                       : 1.000000
Sensor Temperature              : 58.260864
Line Readout Time               : 23076
Rig Relatives                   : -0.45345926367459,-0.299246289583098,0.178292827318906
Principal Point                 : 2.371143,1.836839
Model Type                      : fisheye
Fisheye Affine Symmetric        : 1
Fisheye Affine Matrix           : 1671.093926051,0,0,1671.093926051
Fisheye Polynomial              : 0,1,0.017881608,-0.16164181
GPSXY Accuracy                  : 0.548715
GPSZ Accuracy                   : 0.953000
Flight UUID                     : 44F86636D1233801E519B2EC29A1F4BD
Capture UUID                    : 6FB9933E3BB20D92837D9CE142AF4E94
Sunshine Serial Number          : PI040379BB7K008492
Irradiance Calibration Measurement: 0,600,41,19,1,600,1004,503,2,600,17140,8387,3,600,65535,65535
Calibration Measurement         : 1,0.00427350427350427,514
Calibration Picture             : 0
Irradiance Calibration Measurement Golden: 0,600,38,19.,1,600,947,486.,2,600,15769,7882.,3,600,65535,65535
Irradiance Sensitivities Golden : 614.221848,312.698984
Irradiance Unit Scale           : 1.7873713395012918
Sensor Model                    : 311992417.58091587,4102.139974586678,3223.8629870706945.
Band Name                       : NIR
Central Wavelength              : 790.000000
Wavelength FWHM                 : 40.000000
Black Current                   : 76.000000
Vignetting Polynomial 2D Name   : 0,0,1,0,2,0,3,0,4,0,0,1,0,2,0,3,0,4,1,1,1,2,1,3,2,1,2,2,3,1
Vignetting Polynomial 2D        : 0.7588606611753627,1.0472290605575059,-2.1363409203035819,2.1894221485527647,-1.0565150613962060,0.4239585602722019,-0.6349717485239196,0.3714456229766867,-0.1788391105065560,-1.0573846227800299,1.0258238253111314,-0.0201640346723835,1.1169986400789595,-1.0472817972122375,-0.0261714586792751
Invalid Pixel                   : 152,13
Irradiance List                 : .OMniNQAAAAB2BbkCAQBkAJEeGUNe7J3BOC+EwGnT5TUAAAAAhgXCAgEAZABtHhlD6haewd0ehMCM5+g1AAAAAGwFtQIBAGQARx4ZQwFCnsFMDoTA+v3rNQAAAAB0BbkCAQBkACEeGUM3bZ7Brf2DwG0N7zUAAAAAaQW0AgEAZAD8HRlDDZiewTXtg8BzFPI1AAAAAG8FtgIBAGQA2B0ZQ2zCnsHr3IPAkCL1NQAAAABgBa8CAQBkALMdGUMt7Z7BecyDwEsv+DUAAAAAUgWnAgEAZAAQTBlDegCewenVj8A=.
Exposure Time                   : 1/1444
F Number                        : 2.2
Spectral Sensitivity            : 790 nm
ISO                             : 100
Date/Time Original              : 2018:08:22 13:58:05
Create Date                     : 1970:01:01 00:15:05
Shutter Speed Value             : 1/1444
Aperture Value                  : 2.2
Max Aperture Value              : 2.2
Focal Length                    : 4.0 mm
Image Number                    : 467
Sub Sec Time                    : 683541
Sub Sec Time Original           : 683541
Sub Sec Time Digitized          : 615954
Exif Image Width                : 1280
Exif Image Height               : 960
Focal Plane X Resolution        : 266.6666559
Focal Plane Y Resolution        : 266.6666559
Focal Plane Resolution Unit     : mm
Exposure Mode                   : Auto
Focal Length In 35mm Format     : 30 mm
Image Unique ID                 : 171E0500F46345D825CC563842F8A3DB
Serial Number                   : PI040378AE7K007272
GPS Version ID                  : 2.2.0.0
GPS Latitude Ref                : North
GPS Longitude Ref               : East
GPS Altitude Ref                : Above Sea Level
GPS Time Stamp                  : 13:58:05.663
GPS Status                      : Measurement Active
GPS Speed Ref                   : km/h
GPS Speed                       : 30.37535149
GPS Map Datum                   : WGS-84
GPS Date Stamp                  : 2018:08:22
Black Level Repeat Dim          : 2 2
Black Level                     : 5536 5556 5577 5581
Camera Serial Number            : PI040378AE7K007272
Original Raw File Name          : IMG_180822_135805_0467_NIR.TIF
Aperture                        : 2.2
Image Size                      : 1280x960
Megapixels                      : 1.2
Scale Factor To 35 mm Equivalent: 7.5
Shutter Speed                   : 1/1444
Create Date                     : 1970:01:01 00:15:05.615954
Date/Time Original              : 2018:08:22 13:58:05.683541
Modify Date                     : 2018:08:22 13:58:05.683541
GPS Altitude                    : 293.1 m Above Sea Level
GPS Date/Time                   : 2018:08:22 13:58:05.663000292Z
GPS Latitude                    : 50 deg 59' 7.57" N
GPS Longitude                   : 21 deg 25' 28.88" E
Circle Of Confusion             : 0.004 mm
Field Of View                   : 61.9 deg
Focal Length                    : 4.0 mm (35 mm equivalent: 30.0 mm)
GPS Position                    : 50 deg 59' 7.57" N, 21 deg 25' 28.88" E
Hyperfocal Distance             : 1.81 m
Light Value                     : 12.8
From the picahoo_nir_1 dataset here:
Thank you so much. I have contacted the supplier of the imagery and they have submitted the issue to their engineers. Hopefully they will add this information to the EXIF data to their images.
I went to the GetHub site but do not know how to download the imagery. Is this possible / if so how?
You click on the dataset name in the table.
Here is the link:
Thanks for bringing it to their attention!
Thank you for your help.
