How do I see that ODM uses a GPU?
I installed nvidia-docker and opendronemap/nodeodm:gpu, and checked if a GPU is visible to containers:
chris@laptop1:~$ docker run --rm --gpus all nvidia/cuda:10.0-base nvidia-smi
Unable to find image 'nvidia/cuda:10.0-base' locally
10.0-base: Pulling from nvidia/cuda
25fa05cd42bd: Pull complete
2d6e353a95ec: Pull complete
df0051b6f25d: Pull complete
ad1e3e71b0c0: Pull complete
d26e14de793e: Pull complete
Digest: sha256:2f608ac9f6c6a9abb34112ccd85058877f669d4c976d7e3fc1c7cafcf5ef7dff
Status: Downloaded newer image for nvidia/cuda:10.0-base
Mon Aug 29 20:44:18 2022
| NVIDIA-SMI 470.129.06   Driver Version: 470.129.06   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Quadro M1000M       On   | 00000000:01:00.0 Off |                  N/A |
| N/A   40C    P8    N/A /  N/A |      5MiB /  2002MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
When I start WebODM with webodm.sh start --gpu, the following output is written:
chris@laptop1:~/Downloads/WebODM$ ./webodm.sh start --gpu
01:00.0 VGA compatible controller: NVIDIA Corporation GM107GLM [Quadro M1000M] (rev a2)
01:00.1 Audio device: NVIDIA Corporation GM107 High Definition Audio Controller [GeForce 940MX] (rev a1)
GPU_NVIDIA has been found
Checking for docker...   OK
Checking for docker-compose...   OK
Starting WebODM...
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.gpu.nvidia.yml up --scale node-odm=1
Starting db                ... done
Starting broker            ... done
Starting webodm_node-odm_1 ... done
Starting worker            ... done
Starting webapp            ... done
Attaching to broker, db, webodm_node-odm_1, worker, webapp
When I run a task and monitor using nvidia-smi, I can not observe any usage of the GPU. This might be that the containers GPU usage is hidden to the host system?
