Hi @rormac,
12 km is very doable, but treat it as a corridor survey in several pieces, not one flight. Some pointers:
1. What do you need at the end? Photogrammetry gives you a good orthophoto and terrain/surface model of the corridor, and the towers come out reasonably with oblique shots. The conductors themselves are too thin and will mostly not reconstruct. If the goal is wire sag or vegetation clearance, that’s a LiDAR job; if it’s “where are the towers, what’s the access, what does the corridor look like”, photogrammetry is fine.
2. The line not being on the basemap doesn’t matter. You plan the corridor, not the line. Get the route as KML/coordinates from the utility or the construction plans, or note the tower positions on site with your phone. Another option is a quick high recon flight to make a fast orthophoto, then plan the corridor on that.
3. Fly at least 3 parallel lines, not one. A single strip along the line is the classic way to get a bent or failed reconstruction. With the Air 2S at 80 m AGL:
- The footprint is about 126 m across × 84 m along the flight direction (camera long side across), at roughly 2.3 cm/px.
- For 70% sidelap, space the lines about 38 m apart. Three lines cover a corridor of about 200 m.
- For 80% frontlap you need a photo every ~17 m. At the Air 2S’s 2 s minimum interval, that means no faster than ~8 m/s, and slower is better.
- If you need the towers, add one or two passes with the gimbal at about −45°, looking at the line from both sides.
4. Manual flying with a 2 s interval timer works, as long as you hold a constant height above ground, a constant speed and straight lines. Autonomous flight is more consistent, though. Split the job into chunks of maybe 2–3 km of corridor per battery set, with some overlap between chunks.
5. Ground control matters on long linear jobs. Without RTK, place GCPs along the whole corridor, every ~500 m to 1 km and at both ends. This keeps the long strip from drifting or bending. You can process the chunks separately and merge them, or use split-merge in ODM.
6. Safety: fly well clear of the conductors. The fields near high-voltage lines can upset the compass, so don’t fly right over or between the lines. Also get the utility’s OK.
