I’ve surveyed several lakes, and I need to measure lake volume changes and model how much water is stored for a given increase in lake level. Therefore I don’t need accurate absolute coordinates. I surveyed without GCPs and only with the drone GPS (navigation GPS, not fancy PPK or RTK).
Now I’m having trouble getting the lake shore all at the same vertical level, as it shows variations of several meters. I don’t know how to solve this, but one option I’ve thought of is to create GCPs along the lake shore using the coordinates obtained from an orthomosaic created in an initial run of the reconstruction. Then use those GCPs for a second run, but setting their elevation all to the same value. Ideally, I would like to find a way to tell ODM to give more importance to the vertical coordinate of those GCP than to the horizontal ones, which might be wrong due to the warping of the model in the first run. Is that possible? Any other ideas to get the lake shore level?
We don’t have any weighting capabilities for GCP components, nor GCPs themselves.
Can you tell us more about your survey and data?
What is your mean GPS error for a given dataset? Have you adjusted the --gps-accuracy flag to 2x that to start? Have you enabled --rolling-shutter to test?
If you need high repeatability, then yes, you’ll likely need to use GCPs to keep things constrained.
Hello, this is a task you can solve in the „Cloudcompare“ Software which is Open Source. In Cloudcompare you can align (register) different pointclouds to a reference pointcloud. It is necessary to find equal points, at least 4 but more are better, that haven’t changed coordinates and elevation. With the aligned pointclouds you can also do volume calculations in Cloudcompare.
The align option looks very interesting. Is there more documentation on how it works? It only makes translations, or also rotations, de-warping of some sort?
