I stopped using GPS’s a while back. But I’ve almost always had problems with a Bowling effect on my projects, with or without GCP’s.
When I set “force exif”, my drone takes off from it’s initial point(near the front), up, 100 meters(for example), to an elevation relative to the ground(ground elevation is 1000m + 100m = 1100m elevation), then holds the relative elevation throughout the project, if the back of the project rises 110 meters my drone would run itself into the ground, as it should … I also like tweaking the GPS precision setting to the low side(more precision).
If I don’t “force exif”, and thereby, not define gps precision, that same drone starts out at 1100m, but then dips down in a sort of Bowl(say, 1095m), then rises back up to that same 1100m … a smooth parabola.
I ran elevations(I used to be a surveyor), and the back of the property is about 30 feet higher than the front, with three distinct terraces, with equal upward slopes between each, and a scrub center area.
Is this an acceptable method of ridding myself of this Bowl, or am I playing with fire?
The middle of this property(where the Bowl exists), is a quagmire of brush, and I’ve had GCP’s, N, S, E, and W(but never the middle).
