Hi, after updating ubuntu to 24.04 from 23.10 I got this error when updating or starting Webodm:
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
GPU_NVIDIA has been found
Checking for docker… OK
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.gpu.nvidia.yml -f docker-compose.nodemicmac.yml down --remove-orphans
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/lib/python3/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/lib/python3/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 602, in get
return self.request(“GET”, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 486, in send
resp = conn.urlopen(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 791, in urlopen
response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 497, in _make_request
conn.request(
TypeError: HTTPConnection.request() got an unexpected keyword argument ‘chunked’
File “/usr/bin/docker-compose”, line 33, in
sys.exit(load_entry_point(‘docker-compose==1.29.2’, ‘console_scripts’, ‘docker-compose’)())
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/lib/python3/dist-packages/compose/cli/command.py”, line 60, in project_from_options
return get_project(
File “/usr/lib/python3/dist-packages/compose/cli/command.py”, line 152, in get_project
client = get_client(
File “/usr/lib/python3/dist-packages/compose/cli/docker_client.py”, line 41, in get_client
client = docker_client(
File “/usr/lib/python3/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: HTTPConnection.request() got an unexpected keyword argument ‘chunked’
I have tested docker compose as described here Docker Compose Quickstart | Docker Docs and evething seems ok.
From the research I have made on the web it seems it’s a problem with request and urllib, but I don’t know how to fix.
Thanks for the help
