Hello @pierotofy,
It’s been eight months since I used the WebODM so I just updated to the latest version. I can start webodm in normal mode (Image 1) but when I start in development mode I get error as module ‘node-saas’ cannot be found (Image 2, Image 3 and Image 4). I am currently using Docker CE and Windows 10 Pro. Not sure what am I missing during installation and can you please suggest what might be the issue.
Image 1 (Normal Mode)
Image 2 (Development mode)
Image 3
Image 4
I have been processing data on the normal mode and is working well. I still cannot figure out how to resolve the issue with the development mode. I would be happy if anyone can help or suggest.
Regards
I did try to login into the ‘‘webapp’’ and manually install “node-sass” by command mentioned in link below
https://stackoverflow.com/questions/48147896/error-in-cannot-find-module-node-sass
But still it showed the same error. So I did try to check the .log file. I see that it mentions about npm not being able to find a file. It also mentions that it has to be installed manually. So any suggestions on how can I install them manually or solve this problem…?
Here’s the solution:
sudo npm install --save-dev --unsafe-perm node-sass
Enjoy!
If thist doesn’t work try to install from a mirror
Full Source Available At Here
