Good morning to all.
I need some advice from the community.
I have to fly with a double camera. The two camera between them are rotated 180 degrees for reasons of center of gravity and housing.
When I import the photos in ODM do I have to rotate those of camera 2 rotated 180 degrees or does it not matter?
Thank you all
Hi @A3r0 – it doesn’t matter. OpenDroneMap will calculate the rotation for you.
Out of curiousity, what kind of cameras?
Hi @smathermather, thank’s for your reply.
No secrets, i test two Agrocam (RGB + NDVI) for calculation of vegetation index.
Thank’s to all
Makes sense. Good luck!
Hi @smathermather,
I tried to process a set of 112 images (56 NIR + 56 RGB) but WebODM, after an hour of processing, replies that “=====[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition?”
Do you have any ideas why?
WebODM 1.9.14 on Windows 8.1 16 gb ram and vmdk disk expanded to 150gb
Thank’s
I attach two images of the set
console.pdf (227.7 KB)
