Dear colleagues, what am I doing wrong? In all my attempts to create a multispectral orthomosaic from DJI P4 missions I get obviously segmented result. Does anyone encountered similar effects?
Sorry for the trouble! Could you please start with giving me a bit more information about your system?
For instance:
- Operating System and Version
eg: Windows 11, MacOS 15.1, Ubuntu Linux 20.04LTS, etc… - Hardware Specifications
eg: 32GB RAM, i7-6700k, NVIDIA GTX 1050TI OC, 1TB SSD, etc… - WebODM Install Method
eg: Native installer, Docker, Snap, GitHub download, compiled from source - WebODM/ODM Version
eg: WebODM v1.9.14 Build 63, ODM v2.8.6, etc… - Procesing Node
eg: Automatic, Lightning, local (node-odm-1), etc… - Screenshots demonstrating the issue/behavior/error messages)
I work on Windows 10, AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx 2.10 GHz, 16 GB RAM (Huawei Matebook 13 indeed), WebODM 1.9.2 with default settings (node-odm-1). I choose Option Multispectral and run the task. It finishes correctly but when I import geotiff to QGIS I get segmented result with very unnatural colors for most trees. It looks a bit different inside WebODM viewer but it is segmented in the same way.
Are you able to try on a current release? v1.9.2 is very old.
I have updated to the current WebODM 1.9.14. Nothing has changed. Result is the same with very slight differences. I even do not need to update the figure.
We’re getting similarly poor results from our p4d multispec flights (WebODM 1.9.14). For example:
(and this is one of the “better” outputs)
We have plenty of multispec data we can share if someone wants to look into it.
Please, share small dataset 200-300 images
Here is an example of multispectral dataset.
https://drive.google.com/drive/folders/1uDQXIQXW3h6oYaps-EXOc2rNDNlzCUmm?usp=sharing
This one seems to reconstruct fine:
The purple color variations in the forest (strange?) seem to be due to intensity variation picked up by the red camera:
Are these images coming straight off from the P4 or have they been post-processed somehow?
Would be nice to have access to datasets to test whether this might be an issue with ODM or if it’s an issue with the input data.
And here are results I get. Look quite different. Segmentation becomes obvious after switching to NDVI.
Images come straight from P4. No processing was applied.
Are you using the latest version and what task options did you set? Did you resize the images? ( I didn’t in my test).
Yes. I updated recently and use WebODM 1.9.14 launched from docker. I use default Multispectral settings without resizing images (they are already quite small due to P4 Multispectral camera).
Try the Default preset instead of Multispectral. This might be some issue with the radiometric calibration option.
Edit: or due to texturing-skip-global-seam-leveling. Or both.
Edit2: seems due to texturing-skip-global-seam-leveling, which makes sense.
The key issue is that turning off texturing-skip-global-seam-leveling is going to modify the pixel values to make a “pretty picture”, but the real issue is that the photos have probably been captured with different sun exposure (common) and radiometric calibration with sun+camera has only been tested with Micasense cameras (not sure if it works equally well with the P4).
Yeah camera+sun doesn’t seem to be working.
Opened Add support for P4 camera+sun calibration · Issue #1483 · OpenDroneMap/ODM · GitHub
Processed with :
texturing-skip-global-seam-leveling:True
radiometric-calibration: camera+sun
whit this docker image
NDVI is calculated inside GRASS GIS
Very impressive. This is what I need really. I tried to apply the following options within standard WebODM:
Default - I get purple-colored trees with slight segmentation
Multispectral: texturing-skip-global-seam-leveling: true, radiometric-calibration: camera - I get natural colouring but the strongest segmentation
radiometric-calibration: camera, texturing-skip-global-seam-leveling: false - the best solution so far, but small segmentation present
Could You guide me how to apply Your build?
I have pulled it to docker and run the container. If I understand it right, this is the plain ODM so I need to use command-line interface. Could You provide an example?
Start your WebODM as usual,
execute:
docker run --network webodm_default -d --name node -p 3000:3000 -v ~/:/var/www/data rmitrev/nodeodm_efs:r5a && docker exec -it node cat /etc/hosts
Get ip from output.
then add processing node
Home › Node Management › Processing Nodes › Add Processing Node
Use WebODM as usual.
Great thanks for Your assistance. All this stuff is totally new for me. Looks like magic. But it get more sense with each step.
After running Your command I get the following:
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
172.18.0.7 df08f3f4175b
If I got it right 172.18.0.7 is IP of a new node. But when I add it as a new node it appears in red with a warning:
172.18.0.7:3000 seems to be offline.
And it is impossible to choose it for work.
Are there some additional steps I’m missing?
Try this one:
docker run --network webodm_default -d --name node -p 3000:3000 -v ~/tmp:/var/www/data rmitrev/nodeodm_efs:r5a && docker exec -it node cat /etc/hosts
