DJI Air 3 drone Cannot process dataset
Hi Group.
I have been using DJI Mini 3 and Mini5 for processing of photos to create Orthophoto of a dirt track about 10m wide and around 1.0km long whilst construction over the last 2 months, both flights flown around the 30m height able to capture with about 200 photos, mini 3 JPEG file size around 7000KB and mini 5 JPEG file size 11000kb, and able to run processing with no issues in about 25mins from both drones* (refer WebODM Process notes ) .
With the upgrade last week to the DJI Air 3, I re flew the same area on 25/07/2026. JPEG file sizes around 13000kb with 190 photos taken. Error message ’ Cannot process dataset’.
My thought is that because the Air 3 has 2 lenses, I had flown the track at 95m with the 3 x zoom, this maybe the issue with the dual lens. I changed the photos sizes on Air 3 to 4.8 JPG to see if this made a difference, Error massage appeared, compressed photos JPG file size to about 4000KB. After re running, the error message still appears.
In WebOBM dashboards, Edit Task Options, I have picked the dual camera-lens for the Air 3, however the same message appears and my thought is that the dual camera may be the issue.
I have also run the diagnostic menu, Free: 152.0 GB | Used: 777.9 GB | Total: 929.8 GB
Any thoughts, suggestions helpful.
Torben
Drone Camera specs
DJI Mini 3
1/1.3 inch CMOS sensor features a 1/1.3-inch, a bright f/1.7 aperture, and 4K HDR video recording with dual native ISO
DJI Mini 5
1-inch CMOS sensor, 50-megapixel photo resolution, and a fixed f/1.8 aperture lens
DJI Air 3
dual-primary camera system, utilizing twin 1/1.3-inch CMOS sensors
*WebODM Process notes
DJI Mini 3
Created on: 7/26/2026, 3:27:53 PM
Processing Node: node-odm-1 (manual)
Options: auto-boundary:true
Average GSD: 4.55 cm
Area: 63,823.97 m²
Reconstructed Points: 17,330,982
Spatial Reference: GPS
Disk Usage: 1.02 Gb
Task ID: 0a47c65a-fb20-416a-b737-4ad2074b7232
  • WebODM Process notes
    Mini 5 Pro
    |Created on:|7/4/2026, 6:10:33 PM|
    |Processing Node:|node-odm-1 (manual)|
    |Options:|auto-boundary:true, dsm:true|
    |Average GSD:|2.32 cm|
    |Area:|46,506.32 m²|
    |Reconstructed Points:|23,563,635|
    |Spatial Reference:|GPS|
    |Disk Usage:|1.36 Gb|
    |Task ID:|2c912e7a-1824-4028-ade2-dcd40f1111be|
