Defaults automatically come back?
First of all thank you for all the support here! The support of WebODM is really amazing. Support is half of the product quality, so I rate WebODM really top quality for both the product that just works… and the support!
That being said, I do have an issue again, which is probably my own ignorance to not see the obvious, but I’m really riddled…
So in the WebODM I go to “application → presets” and there I delete the defaults. All of them.
I put my own presets in place…
But the weird thing is - every restart of the server these defaults are back LOL
Not that this is a bug, nor is a big deal of course. I can just select them again and delete them again…
But it would be nice if someone could point out to me where these presets “recovery” comes from so I can permanently delete them. Because I really would just have my own presets there.
Thank you already in advance and again, I really love WebODM. It’s a marvelous piece of software to run over our drone survey data.
Yes it’s a bit of a quirky behavior (it could probably be improved for the aforementioned reasons), to disable it you’d have to edit WebODM/app/boot.py at master · OpenDroneMap/WebODM · GitHub and remove the lines that create the preset objects at boot.
Thank you for pointing out where the defaults are set upon boot… I can easily remove that manually on my end…
Always great the support here by WebODM… Thank you so much
