does anyone have a small dataset (less than 60 images) that does not fully reconstruct, even though it should have sufficient overlap? Examples in this category are often datasets that have vegetation and/or uniform patterns on the ground where part of the map reconstructs but some sections are left off.
I have some ideas I’d like to experiment with to improve image matching, but don’t have a good dataset to test against.
I have some forest areas that won’t reconstruct at all, even tweaking the parameters accordingly. Next try will capture some off-nadir photos. Does it fit your needs?
A couple of issues affect ortho generation of forest areas.
Overlap of images are reduced at canopy height.
Tree tops can move and sway with even slight breezes, making match points difficult to determine.
I fly forest missions as high as possible and increase overlap (especially front) to >85%.
Off-nadir images don’t help much at all, because of the same reasons.
