Hey everyone,
My uploading of images fails after exactly 5 minutes. I have been using the API from webODM to upload images (following this documentation: https://docs.webodm.org/). The images are in total 54 images .JPG with over 700MB of data. Most of the time it takes around or a little less than 5 minutes. And when I want to upload more images it fails it fails always around 5 minutes mark. When the 54 images do get uploaded it takes around 30 minutes to upload.
The time it takes to upload the images is not the problem because I don’t mind if it takes really long as long as it not fails.
I would rather not lower the quality of my images. An option I was looking into was upload the images in batches but didn’t find any documentation only for NodeODM.
The timeout from the Ngrok server shouldn’t be a problem since that should be 8 hours.
what I was wondering is there maybe an automatic timeout from uploading images to webODM? and is there a way around it?
thanks you already for you help, time and efforts! below is the error message from my program, and the options I used.
The error that it shows in my C# .net program says:
System.Net.Http.HttpRequestException: Error while copying content to a stream.
---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host..
---> System.Net.Sockets.SocketException (10054): An existing connection was forcibly closed by the remote host.
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.CreateException(SocketError error, Boolean forAsyncThrow)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ReceiveAsync(Socket socket, CancellationToken cancellationToken)
at System.Net.Sockets.NetworkStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
at System.Net.Security.SslStream.EnsureFullTlsFrameAsync[TIOAdapter](TIOAdapter adapter)
at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine)
at System.Net.Security.SslStream.ReadAsyncInternal[TIOAdapter](TIOAdapter adapter, Memory`1 buffer)
at System.Net.Security.SslStream.ReadAsync(Memory`1 buffer, CancellationToken cancellationToken)
at System.Net.Http.HttpConnection.FillAsync(Boolean async)
at System.Net.Http.HttpConnection.CopyToContentLengthAsync(Stream destination, Boolean async, UInt64 length, Int32 bufferSize, CancellationToken cancellationToken)
at System.Net.Http.HttpConnection.ContentLengthReadStream.CopyToAsync(Stream destination, Int32 bufferSize, CancellationToken cancellationToken)
at System.Net.Http.StreamToStreamCopy.CopyAsync(Stream source, Stream destination, Int32 bufferSize, Boolean disposeSource, CancellationToken cancellationToken)
at System.Net.Http.StreamContent.SerializeToStreamAsync(Stream stream, TransportContext context, CancellationToken cancellationToken)
at System.Net.Http.HttpContent.InternalCopyToAsync(Stream stream, TransportContext context, CancellationToken cancellationToken)
at System.Net.Http.HttpContent.CopyToAsync(Stream stream, TransportContext context, CancellationToken cancellationToken)
at System.Net.Http.MultipartContent.SerializeToStreamAsyncCore(Stream stream, TransportContext context, CancellationToken cancellationToken)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.AsyncStateMachineBox`1.MoveNext(Thread threadPoolThread)
at System.Threading.Tasks.AwaitTaskContinuation.RunOrScheduleAction(IAsyncStateMachineBox box, Boolean allowInlining)
at System.Threading.Tasks.Task.RunContinuations(Object continuationObject)
at System.Net.Http.HttpContent.<CopyToAsync>g__WaitAsync|56_0(ValueTask copyTask)
at System.Net.Http.StreamToStreamCopy.<CopyAsync>g__DisposeSourceAsync|1_0(Task copyTask, Stream source)
at System.Net.Http.HttpConnection.ContentLengthReadStream.CompleteCopyToAsync(Task copyTask, CancellationToken cancellationToken)
at System.Threading.Tasks.Task`1.TrySetResult(TResult result)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.SetExistingTaskResult(Task`1 task, TResult result)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.InvokeContinuation(Action`1 continuation, Object state, Boolean forceAsync, Boolean requiresExecutionContextFlow)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs _)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pNativeOverlapped)
--- End of stack trace from previous location ---
--- End of inner exception stack trace ---
at System.Net.Http.HttpConnection.SendRequestContentAsync(HttpRequestMessage request, HttpContentWriteStream stream, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
details:
my options
dtm: true
dsm: true
auto-boundry:true
dem-resolution: 0.01
feature-quality: ultra
pc-quality: ultra
orthophoto-resolution: 0.01
