Can't find GeoTiff viewer
Hi, I’ve just downloaded webodm repository and install it via docker. It all works.
The only problem I’m facing is that I can’t find any place in the app (web: localhost:8000) where I can upload .tif files and render it on top of a satellite map.
As we can see in the screen shot
Do I need to install something else to get this viewer? Basically I want to integrate this GeoTiff viewer on my react site. As otherwise I have to create this whole thing from scratch
If you want to use the pointcloud (3D) viewer you can use the button in the bottom right corner.
To embed results you can use the share function and use the i-frame option, this works for both 2D / 3D
Hi, where can I find this pointcloud viewer?
In my local installation I can’t find anything, here’s a screen shot
In the ground point cloud interface page, I can’t upload .tif files it only accepts jpg and png
Correct, that is a current limitation of the included POSM GCPI.
You could batch convert to JPEG just for GeoTagging the GCPs.
