Cannot get map to complete
very nice! Now i would still recommend you to think about the Height above ground/above Houses thing i talked about. Flying as low as 150feet with taller Houses you might get problems when choosing 80/80 above ground.
Yeah I will likely see how that works. I’m not sure how it will stitch together doing that but will give it a shot for sure! Sooooo happy to get over this hurdle!! Appreciate the help!
Looking very good!
Thank You sir! Appreciate all the help. It looks good because of this group!
How can I calculate the effective overlap? I’ve seen several references to effective overlap being greater than the actual overlap in a cross grid, but I don’t see it in the documentation. I have a large (for me) project coming up where this might be significant if I can reduce the overlap in a cross grid flight. What if the grids are flown at different heights, or not 90° to each other?
I’ve not found good literature on it, so it isn’t documented yet.
Let me know if you find good literature on it with formulae.
