Calibration reflectance panel pre-processing
I’m pretty sure ODM doesn’t support image calibration based on reflectance panels.
I’m currently using the Sentera reflectance panel and I’d like to preprocess images.
I saw that Sentera has implemented a script but sadly it seems not working with DJI M3M images.
Has someone developed a homemade python script for this… or could someone help me to implement a python script for this?
Thanks in advance
Roberto
Hi Roberto,
Have you found a solution?
Thanks!
Hello Lucia,
Sorry for the delay, the new reply notification was in my spam folder…
Yes, problem solved after contacting Sentera’s support.
The latest version of their scripts is not working, but using this release Release 2024.0722.173322 · SenteraLLC/py-radiometric-corrections · GitHub it’s working well.
It’s not an optimal solution for me, you have to reorganise files and folders before the image processing, but it works…
Let me know if you need support :wink:
Thank you, Roberto! As I’m using Phantom 4 I think I should make some adjustments but for sure it will help.
Lucía
