Any guides on how to add a second computer as a node?
Hi there.
I’m new to this software, and I’m not super technical about networking but I could figure it out if only there is a guide to show me how to add a second node to the computation.
I have a second computer that I’ve installed WebODM (two computers can see each other through wifi network) but I’m not sure how to connect the two.
I appreciate any help! Thanks.
you can add another instance of nodeodm on 2nd machine then on first machine with webodm just add the 2nd machines node in webodm.
running-on-more-than-one-machine
if you’re interested in getting both of the nodes to work on the same task, then you should check out this guide
https://docs.opendronemap.org/large.html#distributed-split-merge
