Abandoned graffiti mill, inside and out — 1,896 images, Mini 5 Pro, poses + scale bar (CC BY 4.0)
Dataset URL: Matt1up/abandoned-graffiti-mill-photogrammetry · Datasets at Hugging Face
Number of images: 1,896
Size in MB: 18,851 for the images (the repo totals 38,138 MB: the same images again as one ZIP, plus poses)
EXIF GPS: yes, all 1,896
GCP: no (scaled from a calibrated bar with two AprilTags instead, see below)
RTK: no
Comment/Description:
Früen Mill, rendered from the reconstruction
This one is the Früen Mill in Minneapolis, in the Bassett Creek valley. It’s a group of mostly reinforced-concrete buildings from the first half of the 20th century, functionally abandoned for more than 50 years and covered in graffiti, inside and out. I flew it with a DJI Mini 5 Pro on October 11, 2026, from 14:44 to 17:05, six batteries. Captured with the property owner’s knowledge and cooperation.
The interior is the interesting part
233 of the photos were taken inside the building. The drone went in through open window bays at three different spots, and 230 of those 233 solve in the same component as the exterior, so the rooms and the outside walls sit in one coordinate frame. The frames shot at the window openings see both inside and out. If your solve splits a room off into its own component, those are the frames to look at. The interior frames are listed in manifest/mill/interior.txt on GitHub, and images.csv has the spot number for every photo.
Interior spot 3
Overall: 1,888 of 1,896 align in one component in RealityScan 2.2.
Capture
  • Native 4096 × 3072 (the sensor’s real readout, not the interpolated 50 MP mode), ISO 100 throughout
  • 2.1 m to 76.4 m above the takeoff point
  • Gimbal from −90° (straight down) to +28.5° (looking up), recorded in each image’s DJI XMP
  • Original aircraft filenames, in capture order
Poses for the original photos
COLMAP cameras.txt / images.txt / points3D.txt (5,710,910 tie points), plus a RealityScan XMP sidecar named after each photo. They are written for the original JPEGs exactly as they download, so there’s no undistortion step and no cropped copies to match up. Each photo has its own camera: RealityScan solved focal length and distortion separately per image, exported as FULL_OPENCV. I tested forcing one shared camera onto all of them and it fits clearly worse, so I’d test that before relying on it in your own solve. If your splatting code only takes pinhole cameras, run COLMAP’s image_undistorter on these first.
1,882 poses ship. Six cameras aligned with impossible focal lengths (27 to 974 mm against 23.95 mm for everything else). They’re close-ups of corrugated metal cladding where the panels repeat and the matcher can’t tell one from the next. I left those six out of the poses, but their photos are still in the set. Expect that cladding to be the weak spot in your own run too.
Scale
A calibrated bar, 1.996 m from tag center to tag center, with two AprilTag 36h11 markers, was laid on the ground and used as control points. The tags are visible in the photos, so you can check it yourself: detected in the originals and placed through the published cameras, they come out 1.9965 m apart, 0.2 mm off. One heads-up: RealityScan numbers 36h11 tags on its own scheme. The control-point file has its labels and the official IDs a detector reports, 476 and 283.
Faces and plates
People were on site. In 33 of the photos, faces (30) or license plates (3) are blurred. The other 1,863 are camera originals, byte for byte. The blurred ones keep their EXIF and DJI XMP. DJI’s embedded preview image was removed from those 33, since it would have shown the faces. All 33 are listed in the README. The poses were solved from the unblurred originals.
Download
CC BY 4.0 covers the photographs and the data. It doesn’t cover the graffiti: the artworks belong to the people who made them.
~Matt
(I had to break all of the url links again in order to get this post to go through if anyone could please edit possibly. thanks)
Hi Matt, I’ve restored the links in your post, they should all work now.
Really cool model, the mill with all the graffiti looks fantastic, and the interior captured through the window bays plus the calibrated scale bar make it a great test case. Thanks a lot for sharing it under CC BY 4.0 and for documenting it so thoroughly!
I’d like to process it myself with ODM soon and will share how it goes.
I have used ai to explore ODM and it looks like the only thing blocking me from using it is my scale bar setup as I do not believe that is something that is implemented. I am currently using Realityscan on Linux/Wine for a custom roof inspection system I have created and would like to eventually switch over to ODM so that I have a real application.
The distance between the two Apriltags on my custom pole is 1.997m.
Do you know if it is easy to implement the scalebar into the ODM processing pipeline?
Short answer: ODM has no scale-bar input – only GCPs with real coordinates, and one known distance isn’t enough for those. But it can be done on ODM’s output, so I built a small tool for it and tested it on your dataset:
odm-bitblade-patches/tools/scalebar at main · Ghost7K/odm-bitblade-patches · GitHub
It reads the solved cameras from ODM (opensfm/reconstruction.json), detects your two tags (36h11, 476/283) in the photos with OpenCV, triangulates each tag center through the cameras (lens distortion included, outliers dropped by reprojection error) and compares the distance with the bar:
pip install numpy opencv-python
python3 odm_scalebar_check.py /path/to/odm/project --tags 476 283 --length 1.99628
Tests on your data:
Reconstruction Tag photos used Reprojection median Distance
Your published poses (converted) 31 / 35 1.3 / 1.2 px 1.9971 m (+0.9 mm; you measured 1.99648)
ODM 3.6.2, only the 196 photos within 20 m of the bar, GPS only 35 / 37 1.4 / 1.4 px 2.0938 m (+4.9 %)
The second line is a nice example of why your bar is useful: on a small patch the Mini’s GPS alone leaves the scale almost 5 % off. With GPS photos the tool is a check; without GPS the printed factor is the scale to apply to the outputs. A real distance constraint inside OpenSfM’s bundle adjustment would be a bigger upstream change.
Could you try it on one of your roof inspection projects and tell me whether the numbers match what RealityScan gives you? I’ll run the full mill dataset through ODM as well and post the result here.
As promised, I ran the whole mill dataset through standard ODM 3.6.2 (Docker, 48 cores / 184 GB RAM), --feature-quality high --pc-quality high --mesh-size 1000000 --mesh-octree-depth 12 --dsm --orthophoto-resolution 2.
1. With ODM’s default image matching only 205 of the 1,896 photos aligned. ODM 3.6.2 picks image pairs by default with --matcher-neighbors 0, which chooses pairs from the triangulated GPS positions. On this mixed flight (nadir, obliques, orbits, interior) that gave only 4,790 pairs (≈ 2.5 per photo), and 89 % of them had no matches.
2. With --matcher-neighbors 30 (each photo matched against its 30 nearest GPS neighbours): 34,431 pairs, 1,864 of 1,896 photos in one reconstruction (RealityScan: 1,888), 254 M dense points, 5 h 23 min in total (SfM 2 h 45, densification 1 h 30, rest about 1 h), peak RAM 89 GB, no swap. So for your setup: use --matcher-neighbors (20–30).
3. Scale check with the tool: tag 476 detected in 75 photos (67 used, median reprojection 1.36 px), tag 283 in 69 (64 used, 0.96 px). Distance in the ODM model: 1.8839 m instead of 1.99628 m → −112 mm (−5.6 %).
To make sure that’s not the tool: a similarity fit of all 1,855 camera centres that both solutions share, ODM vs. your bar-scaled poses, gives the same answer – the whole ODM model is 5.8 % too small (median camera residual 0.78 m).
So here GPS alone leaves ODM’s scale almost 6 % off, both locally at the bar and for the whole model – exactly the case your bar is for. For measurements on this model you’d multiply by the factor the tool prints (1.0597). I haven’t looked into why the GPS scale is that far off yet (the camera positions span about 144 × 125 × 76 m); if you have an idea – different sessions, the Mini 5’s GPS – I’d be interested.
If you try the tool on one of your roof jobs, I’d like to hear how it compares with RealityScan.
Thanks for building the scale-bar tool and running the full dataset through ODM. That’s a really useful result. The --matcher-neighbors 30 tip alone most likely saved me a headache.
I’m going to test it, but it’ll take me a bit. If I do this, I want to set up the whole pipeline end to end and see whether ODM can replace RealityScan for me completely. That means installing ODM properly and working the scale factor from your tool into my process.
For context, here’s what I’m currently doing:
I export a 5–6 million polygon model of a house from RealityScan as a GLB with an 8K texture. A custom three.js app I built lets me brush out roof planes and building footprints and trace a boundary polygon around each plane. It then generates a roofing takeoff report as a PDF (typeset with Tectonic). So far the numbers have perfectly matched real-world tape measurements and EagleView/Hover reports, which are what insurance adjusters and contractors currently use.
Your scale result is encouraging for that use case. My workflow doesn’t need the model itself to be in perfect metric scale, only the measurements that come out of it. If applying the bar’s scale factor to ODM’s output gives the same roof areas and lengths as RealityScan, I may be able to replace RealityScan entirely. I’ll run it on one of my roof jobs and report the comparison here.
I spent today learning to plan and fly automated waypoint missions with QGIS and FlyPath. Everything I’ve flown up to now was manual with timed shots. So I’ll probably have another dataset to share soon: a cross-hatched nadir grid near my house, about 443 × 406 m at 60 m, plus several orbit flights to reduce doming and capture the building facades better.
Thanks again, I’ll report back soon. :slight_smile:
Follow-up on the scale: I found why my ODM run in post 5 came out about 5.6 % too small against your scale bar.
The absolute altitude in the DJI EXIF has a different offset in each of your six flights. The gap between absolute and relative altitude is 329.7 / 354.2 / 357.7 / 359.2 / 359.2 / 352.5 m for flights 1–6. Within one flight it is constant, but across flights the same building ends up at heights up to ~30 m apart, and ODM shrinks the model to make them fit. The barometric relative altitude is consistent across flights (it matches your bar-scaled poses to about 1 m).
Fix: pass a --geo file with each image’s lat/lon from EXIF and altitude = relative altitude + one fixed value (I used +359.2 m):
EPSG:4326
DJI_20261011144439_0001_D.JPG <lon> <lat> <rel_alt + 359.2>
Same settings as before otherwise (incl. --matcher-neighbors 30). Results with ODM 3.6.2:
EXIF altitude relative altitude via --geo
Bar 476 ↔ 283 (scale-bar tool) −5.6 % −14 mm (−0.7 %)
Whole model vs. your poses (similarity fit) 5.8 % too small 0.9 % too small
Camera position residual (median) – 0.25 m
1,865 of 1,896 photos aligned. So for anyone flying several batteries with a DJI drone and no RTK: check alt − rel_alt per flight before trusting the absolute heights.
The textured model is public here (CC BY 4.0, credited to you), the photos are included so you can click through the cameras in the 3D view: Früen Mill · ODM 3.6.2 · Höhen-Fix (rel. Höhe) - WebODM
Thanks again for sharing the dataset, and good luck with the end-to-end pipeline!
I created a model of the mill with 42,342,993 splats.
The scale bar and pose data are what make this set genuinely useful for testing reconstruction pipelines rather than just browsing. Nearly 1,900 images of an abandoned mill interior is a demanding case — low light, repetitive wall texture, and narrow passages tend to trip up feature matching. If you have notes on flight pattern through the tighter rooms, that context would help others interpret alignment failures. CC BY 4.0 is generous. Curious whether any subsets are grouped by area, so people can start with a smaller chunk before processing the whole set.
I really like this model. Looks greate. I think I will have to take care of my setup and get gpu server for splatting
