A GPU-enabled photogrammetry pipeline to generate georeferenced point clouds, orthophotos and elevation models from aerial images using COLMAP.
Not ready for production and everyday use, but it’s a start… and it works! ![]()
I recommend building your docker images if you’re going to try it! I haven’t perfected the build process for all mainstream CPUs yet so the prebuilt image might not work well for your system.
